I recently completed a project to make a guitar pickguard and I would like to make another one. However, when I went to do it I could not get the same result. This is best illustrated with a picture:
A close look at the pickguard, which is made using 2 ply acrylic, shows a faux metal effect done using linear shading. The graphics were created in Inkscape and Imported to Lightburn. The challenge is getting the shading to work consistently. The photo shows that it can be done. However, sometimes I can get it to show and burn correctly, and sometimes I can’t. I settled on the Stucki dither since it gave the best result. The shading is an image, which gets converted to a bitmap in Lightburn. When I use Adjust Image sometimes it shows the shading correctly, and sometimes not: see Lightburn file:
stucki.lbrn2 (717.5 KB)
The file contains 2 images, one which shows correctly in Adjust Image, and one not. I cannot figure out why they are different, since they both came from the same source in Inkscape. When I successfully made the Pickguard, it also showed correctly in Preview. Now even the version that is correct does not show correctly in Preview. Hoping that somebody can enlighten me about the vagaries of using the same dither on different images. BTW all images, good or bad, show the dither shading in the Cut Settings Editor.
