I drawn a simple clock in inkscape for minute markers I used tiled clone function When I imported the file to LB only the original marker is shown. Is there a solution for this?
sorry for my english but I hope you understand what I mean
use the Lightburn circular array tool to clone and rotate your one marker. Far easier in lightburn than most other programs
You can also use the ‘Variable Text’ feature in combination with the Circle Array to auto-generate the clock numbers.
If you can email the SVG file to developer at lightburnsoftware dot com, along with a link to this thread, I can look to see how hard it would be to support this.
Thank you this really works.
