I do a lot of cutting of Basswood on my 33W Atomstack X30 - mostly using the “Trace” function in LightBurn. In many instances though, the spacing between the lines of the trace is narrow and I would like to have the line gap wider. Even though I put most graphic files that I’m going to trace into Photoshop and then enhance it to the best of my ability, when I use trace in LightBurn, in many instances, the spacing between the lines that are going to get cut are very/too narrow - and when I try and pop out the wood pieces between the cuts, it breaks on those narrow areas. I would like to know if there’s a methodology for widening the spacing between the cut lines of an image after the trace has been selected.
Depending on what you’re trying to do, I can think of two methods:
- If you want to make the entire design thicker, you can use Offset to do that.
- If you want to adjust a portion of the design, you can use Edit Nodes to adjust the lines.
I traced outlines on Vellum paper, scanned to a PDF, imported into Lightburn, and then applied Trace to get the cut pattern. I found fat lines worked better to Trace, and Node Edit fixed the weaker sections.
Trace and fix seems to be the only option. Or fix the original image.
Do one more pass following this method:
