kdfurman
(Keith Furman)
April 7, 2021, 5:53pm
1
Traversal lines are burning into designs. I am using a Yora 6550, 15w fixed lens. I tried typing $32=1 into the console but nothing changed. Completely new to this. Need help
Rick
(Technical Evangelist)
April 7, 2021, 6:05pm
2
Just finished this reply to a similar issue.
HI there.
My first post.
I’m sort of a newbie here.
Just wondering how to properly engrave what I’ve traced without getting all those horrible travelling lines between the shapes.
Please help.
If you have a GRBL device, and your laser is still on when moving between shapes, like this:
[image]
It most likely means you are using GRBL 1.1f or later, but do not have the controller in Laser Mode. Fix this by typing $32=1 in the Console window and pressing enter
If you have a Ruida or other DSP controller and are seeing this happen, it is most likely a dying high-voltage power supply unit (PSU). The drive circuit that turns the laser power off and on tends to go first, before the part …
Having said that, if the laser is just on all the time, and typing $32=1 had no effect, you might have a defective laser module.
