I have a new PiBurn Rotary and a Trocen controller on my Laser. I know I can’t use Lightburn to control the rotary and that must be done through the controller but I’m stuck. I need to figure out the Pulse Count number and anytime I try and test anything with the rotary the laser head jogs all the way to the right and starts the job there. I guess I’m clueless on how to actually control it from the controller. Is anyone on here that has a Trocen/rotary combo and is willing to walk me through setup and use? I’m desperate to get up and running. Thanks so much in advance for any help.
I have a PiBurn and a Ruida, but they essentially the same critters…
You need to look at the motor drivers to tell the steps/rotation.
Mine is 2000 steps/rotation… The PiBurn has a 2.5:1 ratio to the driving wheel, so the steps/rotation for the rotary is 2000 X 2.5 = 5000
Steps/rotation of driver X (gear ratio) = steps/rotation in the rotary setup…
Then you only need to know the ‘wheel’ diameter which is about 63… Mine ended up the best at 62mm.
Make sense?
Good luck
