OK, is starting to really weird stuff.
If I launch a program it starts, if i stop it, it jogs ok.
If I home the machine and then i try to jog the software freezes
This is the console output
ok
Starting stream
G21 G54
G91
G1 X-10 Y0 F6000 S0
G90
ALARM:2
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ALARM:2 means it THINKS its going to hit the frame
F6000 is twice the rated speed for the machine
We usually speak in mm/min
but your alarm two means
a) machine doesnt know where it is in space, so probably doesnt home correctly
(You can check this if you go to move pannel, at the top where does it show being? X and Y ?)
b) you are trying to send the machine outside its 400x430 bed, then controler will say “nop cant do that”
At times this can be triggered by job start position. Would need to see your screen to see if thats the case
Just past a full screenshot of your lightburn please
OK, here it is. I’m actually being able to use the machine now… if i do not home it and then use the jog it works, the move to position function works ok…
