I am trying to add a finger slot to the sides of a coaster box. When I select both items to join them together the boolean assistant doesn’t work. The box is one type of line, and the finger slot is another type of line. It worked before but I had the size of the box to small, so I designed a new box with different box generators with the same results. If I make different shapes in lightburn and use the boolean asst. it works fine.
Can we get a screenshot?
If you can attach a LightBurn file that you’re having a problem with we can take a look to see what’s going on.
After I posted in the forum I went back and tried a new box and it works for now.
