Trying to fire up a new Mini Gerbil
I’m stuck at “Waiting for connection” in the Console window. Taking a look at the Debug logs, I keep seeing “Port Open Failed” so it looks like LB isn’t able to open the USB port…?
D: Found port: PID 22336 VID 1155
D: Manufacturer: “tomeko net”
D: Product: “STM32F103C8T6”
D: Name: “ttyACM0”
D: Port open failed
Any quick tips?
Edit: Tries removing machine configuration and recreating it, still nothing.
SOLVED: Had to run LB run as root:
~/LightBurn:$ sudo ./Apprun
Interesting, as I hadn’t had to run it as root for anything else up to the point. I suspect that I need to add myself to some group or check permissions on the port in /dev or something.
Ah well, this worked! :slight_smile:
Oh, you’re running on Linux. Next time you have a question, be sure to mention that. I should’ve caught it, your port name is Linux specific after all, but nobody’s perfect.
You are correct. Do this:
sudo adduser $USER dialout
