Hello, I have a 20W Ortur laser master 2 driven with a MacBook pro and Lightburn V0.9.20. I have the power which seems to be blocked at 100% even with the fire button at 0.25%, I burn everything …
Ortur replaced the laser module and the problem is the same.
Do you have an idea ?
I have the same problem! That and some other problems.
Ortur Laser burning squares instead of designs
If I get my problem fixed maybe you can get yours too!
Would recomend writing at
ortur.tech/support
I pop here now and again but not as often as i should
It’s done I’m waiting for an answer.
I saw the same problem on several forums but there is never a solution …
Regards
