Unable to change min power on image
Not sure whats going on. Created this job a while back and wanted to adjust the min power percent. I know I set it when I originally created the file, but for some reason, I can’t change the min power now? It’s greyed out.
Thanks in advance for your help!
Neither your profile or your post mention what kind of machine you have. If you have a GCode controller, you’ll only be able to change Min Power if you’re using grayscale mode. Otherwise, it’s zero, set by the controller itself.
I was just coming back to say that, lol.
I must have originally had it set for grayscale, then changed to jarvis.
It’s my patented way of figuring something out. Ask for help and 5 minutes later I’ll figure it out.
Running Smoothie on a cohesion board on my cnc machine. I added a diode to it to be able to do larger items than will fit on my k40.
Thanks again!
Honestly, I think the cheap diode I have is dying so was just looking to compensate for it not burning as well as it did before. I was doing some identical items, same program, and it just kept fading so was looking to boost it.
I have a jtech 2.8 coming friday, so will probably chuck this diode and start from scratch then.
Thanks so much for your help.
