Useless software?
I had a similar issue to the OP, Just linking this here in case it’s helpful, my solution is the last reply in the thread.
I also set the transfer mode to synchronus (in Edit>Device settings) just in case: What is Buffered vs Synchronous Transfer Mode
Also that note I have about adding $H to your start gcode, could be the fix for your bounding error, depending on the cause of it.
