Thank you @Colin , Downloaded and will install in the morning.
@jkwilborn YES it is! did not expect this level honestly. ![]()
I had a similar issue to the OP, Just linking this here in case itās helpful, my solution is the last reply in the thread.
I also set the transfer mode to synchronus (in Edit>Device settings) just in case: What is Buffered vs Synchronous Transfer Mode
Also that note I have about adding $H to your start gcode, could be the fix for your bounding error, depending on the cause of it.
One thing I learned is that āout of boundsā errors are caused by the laser head trying to go beyond the defined machine limits when doing raster operations. The process includes overscan because the head canāt stop instantly. This means you can do a vector operation and it works fine then do a raster operation on the same work piece and get an out of bounds error. Makes sense but was not obvious to me for a while.
THANK YOU @Colin COLIN, for the updated exe, Been busy with work so only had a chance to test now, been running for 40 mins and no issues.
I will DM you if there is issues elsewhere, but seems 100% sofar, going to try everything i can.
Thank you @OrturTech for mentioning the Wifi issue with the current stable release.
Overscan works a bit differently between a grbl (Ortur) and a dsp controller like a Ruida.
The dsp will compute the overscan, mine refers to it as a āslopā error. On a grbl itās externally computed by the software.
This is probably a reason that the dsp types have to have the complete job loaded on the controller, not streamed like a grbl machine.
Did not know thatā Excellent insight!
Hi
Could I also get the link?
Iām trying to run my OLM3 over wifi. Fails to complete most jobs.
Cheers
Mark
1.2.02 is required as stated above, should be out very soon
[Boerewors], I hope you got it sorted out. Lightburn is definitely not āuseless softwareā. Too many people using it and too many how-to videos say it is not useless. Read or watch tutorials, ask questions, and you will find Lightburn is way ahead of whoever is in second place. It is awesome that it can work with so many DIFFERENT machines.
Hi Mike,
Yes I know. I was frustrated beyond belief as I have tried so many different things before I posted on here.
Within the thread you will see that I received the assistance needed. Canāt go without LB, nothing else comes close.
That deserves an Amen!
