trille12321
(Tristan Lauritsen)
October 31, 2024, 7:01am
1
Hi,
I have bought a rotary chuck for my 1390 laser.
The Rotary is set up on the U axis and it works fine.
It’s the X axis that moves left to right to engrave on the pipe.
However, I have now rotated my chuck 90 degrees. But it’s still the X axis that moves left to right to engrave. Instead of the Y axis, moving forward and backwards.
Hope someone can help, it’s really frustrating.
JimNM
(James )
October 31, 2024, 7:03am
2
Change your scan angle to 90 degrees from 00 degrees.
trille12321
(Tristan Lauritsen)
October 31, 2024, 7:12am
3
That doesn’t work. The Rotary just stops moving when you change scan angle. I don’t think it’s designed to use the Y axis somehow.
parsec
(FerAS)
October 31, 2024, 8:27am
4
Read this topic;
I have a laser mounted to a CNC router. I have a dedicated A axis rotary that is oriented along the Y axis (wrapping X). I’m trying to figure out how to set up Lightburn to work with it. If I choose A axis in the rotary setup and create gcode to send to the controller (GRBL), only the A axis moves. The gantry stays in place. Is there a setting in Lightburn to let it know that the A axis is aligned along the Y axis? As I mentioned, I’m not using the Y axis motor to turn the rotary. I have a dedic…
Sorry you´re laser is Ruida controlled.
JimNM
(James )
October 31, 2024, 8:45am
5
Did you move your stepper motor control wires? If not, how do you think the controller would know where the laser is?
trille12321
(Tristan Lauritsen)
October 31, 2024, 4:32pm
6
Which stepper motor wire?
The Rotary chuck is connected to the U axis.
I just have to swap wires for x and y everytime I engrave in that direction, that works ok.
JoeSpanier
(Joe Spanier)
October 31, 2024, 8:30pm
7
Currently, we only allow for the X axis being the rotary for certain GRBL devices.
This setup will not work with Ruida Devices
system
(system)
Closed
November 30, 2024, 8:30pm
8
