Variable Text CVS Row Start - End fuction
The Lightburn help suggests that I can choose the Start and End row of a CSV file. I wish only to print a range say row 10 to 20 for a csv file that has a row range of 1 to 100.
WHen I press the Test button my Variable text lightburn file is fully populated. I only whis it to be populated with the Start and End Rows
Start: The first serial number you want to use, or the first row in the CSV file to be used.
End: The last serial number to use, or the last row in the CSV file to use.
Here’s someone who had the same issue. With their explanation of how to correct this issue.
Not the same I am familiar with the offset function.
Re the following
" The values shown are:
Current: The current serial number, or row from the CSV file, that will be displayed.
End: The last serial number to use, or the last row in the CSV file to use."
What function does the “Start” and “End” perform in relation to CSV imports.
My interpretation is that I could select a reange of rows (Start/End) to be imported.
Is this correct?
