Hi LightBurn team,
We are also seeing the same Variable Text scaling / anchoring issue in LightBurn v2.0.05 as Originaly reported & confirmed as Bug here: Variable text max length - not scaling toward center
In short: when using the “Max Width” / “Max length” behavior for text with Squeeze disabled (keep aspect ratio),
the text scales down correctly in size, but it does NOT scale toward the selected Y anchor. If Y alignment is set to Center, longer strings that get scaled down shift upward, so the text is no longer vertically centered in the available space.
This is a production issue for us (badges/labels with CSV variable text), because names vary heavily in length (e.g., 3–20+ chars). Short names look fine, but long names shrink and “float” upward instead of staying centered.
Steps to reproduce (simple):
- Create a text object and enable Variable Text / CSV substitution.
- Set X alignment = Center, Y alignment = Center.
- Enable Max Width for the text (e.g., 50mm) and disable Squeeze (keep aspect ratio).
- Test with a short value (e.g., “ABC”) and a long value (e.g., “ArtisticButchery”).
Result: the long value is scaled down but shifts upward (not centered vertically anymore).
Expected:
- With Y alignment = Center, the scaled text should remain vertically centered (scale toward the center anchor).
Actual: - The text scales, but the vertical position changes (as if the scaling anchor is incorrect).
Is there any update on whether this is already tracked internally, and if/when a fix is planned?
If you need a minimal .lbrn2 sample file, I can provide one.
Thanks a lot & bye from Austia
Andreas
