When Duplicating Object, Outside Cut Line Shifts
Were these designs originally done in another program and transferred using DXF? If so, might be related to this issue discussed in another Topic. The symptoms are actually a bit different so not certain but may be something there. The commonality being that behavior between cut/paste and duplicate are different. In the linked Topic you can actually see the variance in the design. I don’t notice the problem visually in your design, however. Is the issue only seen on the actual burn?
The referenced Topic:
