Wifi connection (telnet stream disconnected) need help
Im getting this message cant conect to wifi, past days i used to work with and now i cant, i already update firmware, reset the machine ( same msg from de app)
Are you certain that the IP address of the laser hasn’t changed, that you are on the same network, and it’s not been firewalled?
If it is connected to the same network and the IP has not changed, it had already been connected previously, it does not work with the application either,
