I just did a wee test with some scavenged resources to try out wire inlay and I’m pretty happy with how it came out!
I scored the channels into this handle using the laser. I was able to just use my beam thickness, I originally tried it with a bit of an offset but it was too loose.
I hammered some copper wire flat, and then hammered it into the channels.
Then sanded the wire down flush, and then sanded the whole handle smooth. I added some boiled linseed oil as I sanded the final grit (600), so it filled in any gaps in the wood grain, and brought it the wood’s colour.
Then I waxed it with some soft wax made from 2 parts boiled linseed oil, 2 parts melted bees wax and 1 part eucalyptus oil (people usually use mineral spirits instead of the eucalyptus, I just prefer the smell of eucalyptus).
The wire thickness varied a lot, because it was hand hammered, but I have some proper flat wire heading my direction, and I’m keen to try more complex designs with that.
Overall this was a really easy little project, and I feel like it would be a really lovely way of labelling one’s tools; instead of writing your name on it you do a little carved inlay.
It would also be an easy way to elevate a little wooden box from a craft store.
For thin lines you can get copper “tape” and sheet stock which would work well with your technique. Even brass and silver sheet would look great, especially in walnut.
Yes, I’ve used 30 gauge tape in a laser kerf. The kerf had to be sized “close” so the tape could be inserted without a lot of force (just light tapping)
Definitely not going to put up with much force before folding
This produced fine lines, you knife handle inserts look a lot thicker but copper is available in a large range of thicknesses. Just thinking it could save a lot of effort versus hammering out of wire.
I have a hunch that the hammered uneven look will be more pleasing to the eye, at least if an organic hand made look is the goal.
Would be, and is for me anyway .
OTOH, flat wire will produce more industrial -or mass produced- look, obviously nothing wrong with that either if that’s the goal.
Maybe a dumb question but why hammer the wire flat before inserting? My first thought is to make the grove such a depth that about 3/4 of the diameter of the round wire is in the grouve with about 1/4 of the diameter protruding above the surface. Put a little CA glue in the bottom of the grove (just in case), put the wire in and hammer it flat. Copper is fair soft so if the wood piece is not too delicate it should handle it. The cooper expands out to grip the sides of the grove. Sand everything flush.
That is a great idea if the item can take the beating. I do inlay with twisted copper wire is a similar fashion but I fill the gaps with colored epoxy then sand away about 1/4 of the wire diameter.
This is after the cutting down, before the sanding
Copper oxidises rapidly so it doesn’t stick well to glue and it’s hard to hammer it in when round; as you try to get the next bit in it deforms the wire, popping the bits you already have in back out. I also don’t like the look of glue, it’s always very obvious where it’s sunk into the grain of the wood.
But if you do it and you like the method and effect it brings, then I’m all for you using it! To each their own, I reckon.
That sure is.
For the “damascus steel look”, one can also use a combination of different metals, either twisted or braided tgether.
The sanding down part of the process can be tricky if the hardness between the materials varies a lot, so some sort of annealing (or purchasing the material in an annealed state) is often required.
One method is also to use a (twisted link) chain, that produces yet another pattern.
If the look or idea of synthetic glues and/or plastics doesn’t tickle ones fancy, there are fauna and flora based resins and fillers available.
The former ones may not fly well with vegan/vegetarian/etc. types of folks, so care have to be taken if that applies to person who for example recieves the item or artwork as a gift.
