Just bought the Ortur Laser Master 2 Pro and using LightBurn on a MacBook. After setting up, the X and Y are at -600. I can’t figure out how to change this. The work surface if 40 cm x 40 cm. below are the parameters from typing “$$”… HELP!!
Could it be possible that you send me a few things for a easier diagnostics
a) Could you provide images of your wiring points
1- Motherboard
2- Both stepper motors
3- Both limit switches
4- Both X and L labeled connectors
b) Could you move head to centre, power on your ORTUR, and using your phone record the 10 seconds it takes for the machine to home please. This way I can see and hear it
c) Could you take 3 images of your belts as machine is idle
The switch shouldnt matter orientation as lon gas the wiring is correct
Now i have 2 questions
a) is your X stepper connected (right side stepper)
if it is, can you unplug the X limit switch, to confirm if by any chance it might be faulty and is istantly reporting “touched” to the controller
I cant see the X motor connection on the images above, maybe you can double check
AS X requires 2 connections. the X extension cable on the left of the machine but also connect the cable to the motor itself.
