So here is the old driver, the DM545A, that show the unaltered switches.
How did you set the switches for the new one? They are differentâŚ
I matched them to the old one, which is incorrect because I have zero clue what to switch them to.
Looking at the table on the side and matching the switch positions:
SW1-SW3 = OFF ON OFF = 3.5 A peak
SW4 = ON = Full Current when stopped
SW5-SW8 = OFF OFF ON OFF = 5000 pulse/rev = 5000 step/rev
The M542ES is Close Enough⢠to work with the same switch settings.
The tables shows it produces 3.31 A peak current, rather than 3.5 A, with the same SW1-SW3 settings. Youâll never notice any difference.
SW4 = ON remains the same to select Full Current when stopped.
Contrary to what I thought, SW5-SW8 select the same step/rev values as the old controller. They are both set for 5000 step/rev.
I expected the new driver might have a different table, so that the same switch settings selected 2500 step/rev, thus driving the X axis motor twice as far for the same number of pulses. However, that is not what is going on.
Two other errors are possible, because Iâve made them: set the switches upside-down or backwards .
With the tables on the stepper driver facing left (as in your picture of the DM545A) and looking straight into the switches, SW1 is on the bottom and SW8 is on the top. The white switch handles are OFF when theyâre left (toward the tables) and ON when theyâre right (toward the finned heatsink).
Getting it upside-down or backwards is very easy when youâre standing on your head inside the electronics bay. ![]()
Take a picture of the switch positions on the new driver to show us theyâre set the way you think they are.
Most likely, you have the switches set correctly, but then weâll all know thatâs not the problem.
Which means we must find another reason why the framing is twice the size it should be. If itâs a factor of 2.54, which is close to âtwiceâ, then (as Jack suggests) suspicion falls on the old inch-vs-millimeter gotcha.
I ended up having a few switches going in the wrong direction. So I fixed them and I framed the project and it looked good! Thank you guys!!! I will test tonight!
Tah dah!
For the record, you are now well beyond âby no means even close to an electricianâ and entering âIâve made that mistake beforeâ territory.
Welcome to the neighborhood!
