Hello, have a D1 pro with the extensions installed. Firmware is current. I am having a strange problem related to the height of my pieces. For example, in the design I have the dimensions set to 5x5, but when the laser cuts it, it is cut 5x5.5. For some reason the height is getting extended. It also does it proportionally with other parts of the design, stretches them out so to speak.
The only thing I have done recently as far as changes is to upgrade to LB 1.4.01. Do I need to recalibrate something or is there something else I can try.
Check all rotary settings are off
That was it, thank you very much. Now I am going to go play in traffic lol. I can’t believe I glossed over that.
