Xtool D1 Pro Home Position Problem
Grinding while homing is usually either the limit switch is bad, the plug is loose, or the cable that runs up to the toolhead is in the way. I suggest rerouting the cables outside of the frame so they do not jam against it and keep it from homing properly.
