So I recently added the extension to my D1 pro and cannot get the laser working. It frames correctly but I cannot run a job, as soon as I start it regimes and fan on laser kees running til I stop job.
Hi Aldo,
Have you updated your Grbl settings
Type in console $131=936
Press enter
That should help
Thanks no I have not. Farely new and still trying to learn the software, I barely found this forum and there’s lots of great info here. I will see about that when I get home today. Thanks for your reply
Won’t stay at 936. After I type in $131=936 then enter it says ok ok but then I type in $$ enter and it says it’s still 432. I updated in XCS already and everything seems to be working there but I would like to continue using lightburn since pretty much everything I do is in lightburn
You might need to use XCS to update the D1 firmware first.
Sorry to step in.
You might want to give a look at this topic.
Thank you fer. I should have closed this post.
