2 days ago I was able to make an 8 sheet R2-D2 being able to cut with tabs the first try each sheet
Yesterday morning after updating lightburn I went to cut a different model with tabs and I set it up with the same settings. And I wasn’t able to pop the pieces out
I was frustrated so I gave up for the night. Today march 5th i went to testing for cuts with tabs it was jumpy when it was cutting with tabs. I would upload a video but it won’t allow me
I ran a second test without tabs and it ran perfect no jumps consistent movement speed. The right is with tabs and the left is without all tabs are set at .1mm and 4 tabs per shape each box is at a different speed setting
This is the bottom of the board the left is with tabs and the right is without
If someone from lightburn would like to see the video please send me an email address.
I attempted to revert to the previous version of lightburn and the problem continued. Can someone please help. I apologize for posting the same issue on a different thread but this one explains my situation better
Thank you for your time
Richard p
Update if I keep the speed under 350mm/min it doesn’t jump.
This is after 1 pass 500mm/min no constant power 25% power tabs are on .1mm automatic 50.0 spacing
This is the same exact settings except 350mm/min after 1 pass
Update 3/6/22
I downloaded the 1.1.01 patch and the problem is still happening. I tried putting the tab power on 1 and the laser speed on 1000mm/min and the head stayed a consistent speed but it didn’t leave any tabs. Does anyone from lightburn have any ideas on how to fix this problem. I will not be able to make clean 3d wood models without this being fixed. I do not have the air assist for the xtool d1
JohnJohn
(John Johnson)
March 7, 2022, 5:40pm
5
What isn’t jumping?
I’m not going to ask for your woodworking art files but if you could share the test file with the squares somebody here may be able to figure out what’s going on.
so to explain the problem better between 2000mm/min and 360mm/min when i am cutting with tabs on. the laser will cut the until the tab the laser will pulse like it is ment to for a tab and when the laser fires again it is at a higher speed then before the tab. when the laser gets to the next edge, it reprats the process here is a picture of this program. if your were to run extra passes it would cut through like the above pictures
test square.lbrn2 (59.1 KB)
I look forward to hearing a response
JohnJohn
(John Johnson)
March 7, 2022, 9:53pm
7
0.1 mm tab size is pretty small - it’s .004" you might want to be about double the dot size or kerf of your cut.
I’ve exported the GCode of your file and there is nothing strange in here at all - it’s very simple G1 and G0 moves. It’s possible that the D1 is reverting back to rapid rate when a G0 move is issued - we’ve seen all kinds of flawed versions of GRBL firmware from various vendors, so it wouldn’t surprise me.
I’ll ask the XTool folks if they can verify this.
ok will do thank you for the help
JohnJohn
(John Johnson)
March 8, 2022, 8:08pm
10
Richard,
Just out of curiosity - can you enter $$ into the Console window so I can see what the maximum feed rate is?
Just type the following into the console window:
then hit enter.
Just copy and paste that report into a reply here. I’m curious about the speed settings on your Xtool D1.
no problem.
ok
$0=1
$1=0.03
$2=0
$3=0
$4=0
$5=0
$6=0
$10=255
$11=0.0
$12=0.0
$13=0
$20=1
$21=0
$22=1
$23=0
$24=25.000
$25=3000.000
$26=250
$27=1.000
$30=1000
$31=0.1
$32=1
$100=100.000
$101=100.000
$102=100.000
$110=12000.000
$111=12000.000
$112=12000.000
$120=1000.000
$121=300.000
$122=300.000
$130=432.000
$131=406.000
$132=0.000
ok
does everything look correct?
JohnJohn
(John Johnson)
March 9, 2022, 4:51am
12
You said in the title that the laser is moving abnormally fast.
One of the things that can happen during an update is a loss of some of the settings. Can you open the Cuts/Layers window and confirm that it’s still requesting the cut in mm/min?
After you confirm those units, please open the Settings window. It’s under Edit - then wheel down to the Settings (gears icon) and click that. Make sure this is in mm/minute as well.
Richp7557:
$110=12000.000
$111=12000.000
$112=12000.000
$120=1000.000
$121=300.000
$122=300.000
12000 mm/min travel speeds for x, y & z seem kind of fast for some of the devices i’ve worked with. I would try to engrave a square 1200 mm on a side (on a wasteboard at super-low power) and time it with a stopwatch to see if a tenth of a minute (6 seconds) is reasonably close for one of the sides. I suspect that 6000mm/min and 12 seconds would be realistic but i haven’t measured an Xtool d1 yet.
$120 is an acceleration for the x-axis and $121 is an acceleration for the y-axis. I don’t often find them this disparate in the wild. My Bachin Maker has a similar X-Y axis set up and mine shows 500mm/s^2 for both of those.
I ran 1 square 131x131mm at 1200mm/min and it took 4.6sec to run the bottom line of the square
JohnJohn
(John Johnson)
March 9, 2022, 3:24pm
14
Interesting!
131mm/(4.6/60) = 1708mm/min
(131mm/1200mm/min)*60 = 6.55 sec
In the Console window, there’s a switch on the right hand side that says “Show all”. Please click that and when it’s green run this test square again. That will report all the G-code. I don’t think it’ll be a ton of lines. Please copy and paste that report into a reply here.
It appears that either the GRBL controller is misbehaving or Lightburn is telling it to run fast.
this is all i could get
G1 X0.787S1000
G1 X0.742S0
G1 X2.361S1000
G1 X2.736S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.007S0
G1 X0.794S1000
G1 X2.483S0
G1 X0.786S1000
G1 X0.834S0
G1 X0.794S1000
G1 X2.483S0
G1 X0.786S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.246S0
G1 X-0.785S1000
G1 X-2.491S0
G1 X-0.792S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.491S0
G1 X-0.793S1000
G1 X-2.006S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.835S0
G1 X-0.785S1000
G1 X-2.498S0
G1 X-0.786S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.498S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.498S0
G1 X-0.786S1000
G1 X-1.898S0
G1 X-1.056S1000
G1 X-108.374S0
G1 X-0.784S1000
G1 X-2.493S0
G1 X-0.792S1000
G1 X-0.827S0
G1 X-0.785S1000
G1 X-2.492S0
G1 X-0.792S1000
G1 X-2.006S0
G1 X-0.769S1000
G1 X-4.003S0
G1 X-1.055S1000
G1 X-5.673S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.784S1000
G1 X-2.499S0
G1 X-0.786S1000
G1 X-0.827S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-1.004S0
G1 X-0.95S1000
G1 X-1.25S0
G1 X-0.139Y-0.1S0
G1 X1.25S0
G1 X1.029S1000
G1 X1.063S0
G1 X0.786S1000
G1 X2.505S0
G1 X0.782S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.504S0
G1 X0.783S1000
G1 X0.823S0
G1 X0.786S1000
G1 X2.505S0
G1 X0.782S1000
G1 X5.78S0
G1 X1.046S1000
G1 X3.902S0
G1 X0.769S1000
G1 X2.005S0
G1 X0.79S1000
G1 X2.5S0
G1 X0.783S1000
G1 X0.823S0
G1 X0.79S1000
G1 X2.501S0
G1 X0.783S1000
G1 X108.48S0
G1 X1.047S1000
G1 X1.796S0
G1 X0.787S1000
G1 X2.503S0
G1 X0.783S1000
G1 X0.824S0
G1 X0.786S1000
G1 X2.504S0
G1 X0.783S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.503S0
G1 X0.783S1000
G1 X5.832S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.005S0
G1 X0.791S1000
G1 X2.499S0
G1 X0.783S1000
G1 X0.824S0
G1 X0.79S1000
G1 X2.499S0
G1 X0.783S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.246S0
G1 X-0.781S1000
G1 X-2.507S0
G1 X-0.789S1000
G1 X-0.82S0
G1 X-0.781S1000
G1 X-2.507S0
G1 X-0.789S1000
G1 X-2.004S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.828S0
G1 X-0.782S1000
G1 X-2.508S0
G1 X-0.788S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.787S1000
G1 X-0.819S0
G1 X-0.782S1000
G1 X-2.508S0
G1 X-0.788S1000
G1 X-1.699S0
G1 X-1.033S1000
G1 X-108.587S0
G1 X-0.781S1000
G1 X-2.508S0
G1 X-0.789S1000
G1 X-0.818S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.788S1000
G1 X-2.004S0
G1 X-0.769S1000
G1 X-3.807S0
G1 X-1.031S1000
G1 X-5.886S0
G1 X-0.781S1000
G1 X-2.51S0
G1 X-0.787S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.788S1000
G1 X-0.818S0
G1 X-0.781S1000
G1 X-2.51S0
G1 X-0.787S1000
G1 X-1.141S0
G1 X-1.094S1000
G1 X-1.25S0
G1 X-1.139Y-0.1S0
G1 X1.25S0
G1 X0.139S1000
G1 X0.731S0
G1 X1.272S1000
G1 X1.231S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X0.814S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X5.987S0
G1 X1.019S1000
G1 X3.715S0
G1 X0.769S1000
G1 X2.003S0
G1 X0.787S1000
G1 X2.51S0
G1 X0.785S1000
G1 X0.814S0
G1 X0.787S1000
G1 X2.511S0
G1 X0.784S1000
G1 X108.689S0
G1 X1.02S1000
G1 X1.606S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X0.815S0
G1 X0.788S1000
G1 X2.51S0
G1 X0.783S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X5.825S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.003S0
G1 X0.788S1000
G1 X2.51S0
G1 X0.784S1000
G1 X0.815S0
G1 X0.787S1000
G1 X2.511S0
G1 X0.783S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.248S0
G1 X-0.788S1000
G1 X-2.511S0
G1 X-0.785S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.511S0
G1 X-0.786S1000
G1 X-2.002S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.823S0
G1 X-0.788S1000
G1 X-2.507S0
G1 X-0.79S1000
G1 X-0.811S0
G1 X-0.789S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.507S0
G1 X-0.79S1000
G1 X-1.513S0
G1 X-1.014S1000
G1 X-108.785S0
G1 X-0.789S1000
G1 X-2.51S0
G1 X-0.786S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.511S0
G1 X-0.785S1000
G1 X-2.002S0
G1 X-0.769S1000
G1 X-3.623S0
G1 X-1.013S1000
G1 X-6.084S0
G1 X-0.788S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-0.812S0
G1 X-0.789S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-1.338S0
G1 X-2.022S1000
G1 X-1.25S0
G1 X0.013Y-0.1S0
G1 X1.25S0
G1 X1.864S1000
G1 X1.484S0
G1 X0.789S1000
G1 X2.503S0
G1 X0.789S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X0.816S0
G1 X0.789S1000
G1 X2.503S0
G1 X0.788S1000
G1 X6.185S0
G1 X1.007S1000
G1 X3.531S0
G1 X0.769S1000
G1 X2.003S0
G1 X0.781S1000
G1 X2.511S0
G1 X0.788S1000
G1 X0.816S0
G1 X0.782S1000
G1 X2.511S0
G1 X0.788S1000
G1 X108.887S0
G1 X1.007S1000
G1 X1.422S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X0.816S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.789S1000
G1 X5.825S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.003S0
G1 X0.782S1000
G1 X2.511S0
G1 X0.788S1000
G1 X0.815S0
G1 X0.783S1000
G1 X2.51S0
G1 X0.789S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.253S0
G1 X-0.788S1000
G1 X-2.509S0
G1 X-0.781S1000
G1 X-0.819S0
G1 X-0.788S1000
G1 X-2.508S0
G1 X-0.781S1000
G1 X-2.004S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.828S0
G1 X-0.789S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-0.819S0
G1 X-0.788S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-0.819S0
G1 X-0.789S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-1.336S0
G1 X-0.996S1000
G1 X-108.988S0
G1 X-0.788S1000
G1 X-2.507S0
G1 X-0.782S1000
G1 X-0.819S0
G1 X-0.789S1000
G1 X-2.507S0
G1 X-0.781S1000
G1 X-2.004S0
G1 X-0.769S1000
G1 X-3.447S0
G1 X-0.994S1000
G1 X-6.284S0
G1 X-0.789S1000
G1 X-2.5S0
G1 X-0.788S1000
G1 X-0.82S0
G1 X-0.788S1000
G1 X-2.5S0
G1 X-0.789S1000
G1 X-0.819S0
G1 X-0.788S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-1.678S0
G1 X-1.658S1000
G1 X-1.25S0
G1 X0.012Y-0.1S0
G1 X1.25S0
G1 X1.373S1000
G1 X1.952S0
G1 X0.787S1000
G1 X2.498S0
G1 X0.788S1000
G1 X0.823S0
G1 X0.788S1000
G1 X2.497S0
G1 X0.789S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.498S0
G1 X0.788S1000
G1 X6.375S0
G1 X0.984S1000
G1 X3.369S0
G1 X0.769S1000
G1 X2.005S0
G1 X0.786S1000
G1 X2.499S0
G1 X0.788S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.498S0
G1 X0.789S1000
G1 X109.078S0
G1 X0.985S1000
G1 X1.26S0
G1 X0.788S1000
G1 X2.498S0
G1 X0.788S1000
G1 X0.822S0
G1 X0.788S1000
G1 X2.498S0
G1 X0.789S1000
G1 X0.822S0
G1 X0.787S1000
G1 X2.499S0
G1 X0.788S1000
G1 X5.831S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.005S0
G1 X0.785S1000
G1 X2.5S0
G1 X0.789S1000
G1 X0.822S0
G1 X0.786S1000
G1 X2.5S0
G1 X0.788S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.252S0
G1 X-0.789S1000
G1 X-2.491S0
G1 X-0.791S1000
G1 X-0.826S0
G1 X-0.788S1000
G1 X-2.492S0
G1 X-0.791S1000
G1 X-2.005S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.834S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.826S0
G1 X-0.789S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.826S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-1.191S0
G1 X-0.967S1000
G1 X-109.169S0
G1 X-0.789S1000
G1 X-2.49S0
G1 X-0.791S1000
G1 X-0.827S0
G1 X-0.788S1000
G1 X-2.49S0
G1 X-0.792S1000
G1 X-2.005S0
G1 X-0.769S1000
G1 X-3.303S0
G1 X-0.962S1000
G1 X-6.466S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.826S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.827S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-1.765S0
G1 X-1.547S1000
G1 X-1.25S0
G1 X0.012Y-0.1S0
G1 X1.25S0
G1 X1.67S1000
G1 X1.636S0
G1 X0.787S1000
G1 X2.486S0
G1 X0.787S1000
G1 X0.836S0
G1 X0.787S1000
G1 X2.487S0
G1 X0.786S1000
G1 X0.837S0
G1 X0.787S1000
G1 X2.486S0
G1 X0.787S1000
G1 X6.558S0
G1 X0.934S1000
G1 X3.243S0
G1 X0.769S1000
G1 X2.011S0
G1 X0.792S1000
G1 X2.481S0
G1 X0.787S1000
G1 X0.836S0
G1 X0.792S1000
G1 X2.482S0
G1 X0.786S1000
G1 X109.262S0
G1 X0.939S1000
G1 X1.135S0
G1 X0.787S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.834S0
G1 X0.787S1000
G1 X2.489S0
G1 X0.787S1000
G1 X0.834S0
G1 X0.787S1000
G1 X2.488S0
G1 X0.787S1000
G1 X5.838S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.01S0
G1 X0.792S1000
G1 X2.483S0
G1 X0.787S1000
G1 X0.834S0
G1 X0.793S1000
G1 X2.483S0
G1 X0.786S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.255S0
G1 X-0.784S1000
G1 X-2.474S0
G1 X-0.79S1000
G1 X-0.848S0
G1 X-0.785S1000
G1 X-2.474S0
G1 X-0.79S1000
G1 X-2.018S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.843S0
G1 X-0.784S1000
G1 X-2.478S0
G1 X-0.786S1000
G1 X-0.849S0
G1 X-0.784S1000
G1 X-2.477S0
G1 X-0.787S1000
G1 X-0.848S0
G1 X-0.784S1000
G1 X-2.478S0
G1 X-0.786S1000
G1 X-1.09S0
G1 X-0.913S1000
G1 X-109.347S0
G1 X-0.784S1000
G1 X-2.473S0
G1 X-0.789S1000
G1 X-0.851S0
G1 X-0.783S1000
G1 X-2.473S0
G1 X-0.789S1000
G1 X-2.02S0
G1 X-0.769S1000
G1 X-3.191S0
G1 X-0.909S1000
G1 X-6.641S0
G1 X-0.783S1000
G1 X-2.476S0
G1 X-0.786S1000
G1 X-0.851S0
G1 X-0.784S1000
G1 X-2.475S0
G1 X-0.787S1000
G1 X-0.851S0
G1 X-0.783S1000
G1 X-2.476S0
G1 X-0.786S1000
G1 X-1.529S0
G1 X-1.184S1000
G1 X-1.25S0
G1 X0.238Y-0.1S0
G1 X1.25S0
G1 X1.039S1000
G1 X1.445S0
G1 X0.786S1000
G1 X2.464S0
G1 X0.781S1000
G1 X0.865S0
G1 X0.786S1000
G1 X2.464S0
G1 X0.782S1000
G1 X0.865S0
G1 X0.786S1000
G1 X2.464S0
G1 X0.781S1000
G1 X6.715S0
G1 X0.883S1000
G1 X3.148S0
G1 X0.769S1000
G1 X2.028S0
G1 X0.787S1000
G1 X2.464S0
G1 X0.781S1000
G1 X0.865S0
G1 X0.786S1000
G1 X2.464S0
G1 X0.781S1000
G1 X109.423S0
G1 X0.887S1000
G1 X1.054S0
G1 X0.787S1000
G1 X2.466S0
G1 X0.781S1000
G1 X0.863S0
G1 X0.786S1000
G1 X2.466S0
G1 X0.782S1000
G1 X0.862S0
G1 X0.787S1000
G1 X2.466S0
G1 X0.781S1000
G1 X5.849S0
G1 X0.769S1000
G1 X3.516S0
G1 X0.768S1000
G1 X2.027S0
G1 X0.787S1000
G1 X2.466S0
G1 X0.781S1000
G1 X0.863S0
G1 X0.786S1000
G1 X2.466S0
G1 X0.782S1000
G1 X1.25S0
G1 X-0.006Y-0.1S0
G1 X-1.25S0
G1 X-0.781S1000
G1 X-2.447S0
G1 X-0.791S1000
G1 X-0.877S0
G1 X-0.782S1000
G1 X-2.447S0
G1 X-0.791S1000
G1 X-2.036S0
G1 X-0.768S1000
G1 X-3.516S0
G1 X-0.769S1000
G1 X-5.854S0
G1 X-0.782S1000
G1 X-2.452S0
G1 X-0.786S1000
G1 X-0.876S0
G1 X-0.782S1000
G1 X-2.453S0
G1 X-0.785S1000
G1 X-0.877S0
G1 X-0.782S1000
G1 X-2.452S0
G1 X-0.786S1000
G1 X-1.021S0
G1 X-0.867S1000
G1 X-109.49S0
G1 X-0.783S1000
G1 X-2.442S0
G1 X-0.792S1000
G1 X-0.879S0
G1 X-0.783S1000
G1 X-2.443S0
G1 X-0.792S1000
G1 X-2.037S0
G1 X-0.769S1000
G1 X-3.108S0
G1 X-0.864S1000
G1 X-6.779S0
G1 X-0.783S1000
G1 X-2.449S0
G1 X-0.786S1000
G1 X-0.879S0
G1 X-0.783S1000
G1 X-2.448S0
G1 X-0.786S1000
G1 X-0.879S0
G1 X-0.783S1000
G1 X-2.449S0
G1 X-0.786S1000
G1 X-1.378S0
G1 X-0.947S1000
G1 X-1.25S0
G1 X0.134Y-0.1S0
G1 X1.25S0
G1 X0.876S1000
G1 X1.325S0
G1 X0.786S1000
G1 X2.426S0
G1 X0.789S1000
G1 X0.895S0
G1 X0.787S1000
G1 X2.426S0
G1 X0.788S1000
G1 X0.896S0
G1 X0.786S1000
G1 X2.426S0
G1 X0.789S1000
G1 X6.834S0
G1 X0.846S1000
G1 X1.541S0
G1 X0.062S1000
G1 X1.475S0
G1 X0.769S1000
G1 X2.047S0
G1 X0.797S1000
G1 X2.415S0
G1 X0.789S1000
G1 X0.895S0
G1 X0.797S1000
G1 X2.415S0
G1 X0.789S1000
G1 X109.545S0
G1 X0.849S1000
G1 X1S0
G1 X0.786S1000
G1 X2.431S0
G1 X0.789S1000
G1 X0.891S0
G1 X0.785S1000
G1 X2.431S0
G1 X0.789S1000
G1 X0.891S0
G1 X0.786S1000
G1 X2.431S0
G1 X0.789S1000
G1 X4.322S0
G1 X0.023S1000
G1 X1.514S0
G1 X0.769S1000
G1 X1.979S0
G1 X0.023S1000
G1 X1.514S0
G1 X0.768S1000
G1 X2.045S0
G1 X0.797S1000
G1 X2.42S0
G1 X0.788S1000
G1 X0.891S0
G1 X0.797S1000
G1 X2.42S0
G1 X0.789S1000
G1 X1.25S0
G1 X-0.016Y-0.1S0
G1 X-1.25S0
G1 X-0.786S1000
G1 X-2.392S0
G1 X-0.796S1000
G1 X-0.923S0
G1 X-0.785S1000
G1 X-2.393S0
G1 X-0.795S1000
G1 X-2.061S0
G1 X-0.768S1000
G1 X-1.285S0
G1 X-0.252S1000
G1 X-1.979S0
G1 X-0.769S1000
G1 X-1.284S0
G1 X-0.253S1000
G1 X-4.339S0
G1 X-0.785S1000
G1 X-2.402S0
G1 X-0.786S1000
G1 X-0.923S0
G1 X-0.785S1000
G1 X-2.402S0
G1 X-0.786S1000
G1 X-0.924S0
G1 X-0.785S1000
G1 X-2.402S0
G1 X-0.786S1000
G1 X-0.986S0
G1 X-0.832S1000
G1 X-109.609S0
G1 X-0.784S1000
G1 X-2.388S0
G1 X-0.795S1000
G1 X-0.929S0
G1 X-0.785S1000
G1 X-2.388S0
G1 X-0.794S1000
G1 X-2.064S0
G1 X-0.769S1000
G1 X-1.245S0
G1 X-0.292S1000
G1 X-1.511S0
G1 X-0.832S1000
G1 X-6.895S0
G1 X-0.784S1000
G1 X-2.397S0
G1 X-0.786S1000
G1 X-0.93S0
G1 X-0.784S1000
G1 X-2.397S0
G1 X-0.786S1000
G1 X-0.929S0
G1 X-0.784S1000
G1 X-2.397S0
G1 X-0.786S1000
G1 X-1.29S0
G1 X-0.839S1000
G1 X-1.25S0
G1 X0.064Y-0.1S0
G1 X1.25S0
G1 X0.816S1000
G1 X1.265S0
G1 X0.787S1000
G1 X2.367S0
G1 X0.78S1000
G1 X0.963S0
G1 X0.786S1000
G1 X2.367S0
G1 X0.781S1000
G1 X0.962S0
G1 X0.787S1000
G1 X2.367S0
G1 X0.78S1000
G1 X6.942S0
G1 X0.819S1000
G1 X1.494S0
G1 X0.5S1000
G1 X1.037S0
G1 X0.769S1000
G1 X2.08S0
G1 X0.793S1000
G1 X2.361S0
G1 X0.78S1000
G1 X0.963S0
G1 X0.793S1000
G1 X2.36S0
G1 X0.78S1000
G1 X109.656S0
G1 X0.821S1000
G1 X0.984S0
G1 X0.786S1000
G1 X2.373S0
G1 X0.78S1000
G1 X0.957S0
G1 X0.787S1000
G1 X2.372S0
G1 X0.781S1000
G1 X0.957S0
G1 X0.786S1000
G1 X2.373S0
G1 X0.78S1000
G1 X4.356S0
G1 X0.469S1000
G1 X1.068S0
G1 X0.769S1000
G1 X1.979S0
G1 X0.468S1000
G1 X1.069S0
G1 X0.768S1000
G1 X2.078S0
G1 X0.793S1000
G1 X2.365S0
G1 X0.781S1000
G1 X0.957S0
G1 X0.793S1000
G1 X2.366S0
G1 X0.781S1000
G1 X1.25S0
G1 X-0.017Y-0.1S0
G1 X-1.25S0
G1 X-0.781S1000
G1 X-2.334S0
G1 X-0.791S1000
G1 X-0.991S0
G1 X-0.78S1000
G1 X-2.335S0
G1 X-0.79S1000
G1 X-2.095S0
G1 X-0.768S1000
G1 X-0.885S0
G1 X-0.652S1000
G1 X-1.979S0
G1 X-0.769S1000
G1 X-0.885S0
G1 X-0.652S1000
G1 X-4.373S0
G1 X-0.78S1000
G1 X-2.339S0
G1 X-0.786S1000
G1 X-0.991S0
G1 X-0.78S1000
G1 X-2.339S0
G1 X-0.787S1000
G1 X-0.991S0
G1 X-0.78S1000
G1 X-2.339S0
G1 X-0.786S1000
G1 X-0.984S0
G1 X-0.808S1000
G1 X-109.702S0
G1 X-0.782S1000
G1 X-2.328S0
G1 X-0.79S1000
G1 X-0.997S0
G1 X-0.781S1000
G1 X-2.328S0
G1 X-0.791S1000
G1 X-2.097S0
G1 X-0.769S1000
G1 X-0.853S0
G1 X-0.684S1000
G1 X-1.477S0
G1 X-0.806S1000
G1 X-6.989S0
G1 X-0.781S1000
G1 X-2.332S0
G1 X-0.787S1000
G1 X-0.996S0
G1 X-0.782S1000
G1 X-2.332S0
G1 X-0.786S1000
G1 X-0.997S0
G1 X-0.781S1000
G1 X-2.332S0
G1 X-0.787S1000
G1 X-1.245S0
G1 X-0.81S1000
G1 X-1.25S0
G1 X0.035Y-0.1S0
G1 X1.25S0
G1 X0.795S1000
G1 X1.242S0
G1 X0.787S1000
G1 X2.292S0
G1 X0.787S1000
G1 X1.031S0
G1 X0.786S1000
G1 X2.292S0
G1 X0.788S1000
G1 X1.03S0
G1 X0.787S1000
G1 X2.292S0
G1 X0.787S1000
G1 X4.598S0
G1 X0.043S1000
G1 X2.381S0
G1 X0.8S1000
G1 X1.467S0
G1 X0.857S1000
G1 X0.68S0
G1 X0.769S1000
G1 X2.114S0
G1 X0.794S1000
G1 X2.285S0
G1 X0.787S1000
G1 X1.03S0
G1 X0.795S1000
G1 X2.284S0
G1 X0.788S1000
G1 X109.738S0
G1 X0.801S1000
G1 X0.989S0
G1 X0.786S1000
G1 X2.299S0
G1 X0.786S1000
G1 X1.025S0
G1 X0.787S1000
G1 X2.299S0
G1 X0.786S1000
G1 X1.025S0
G1 X0.786S1000
G1 X2.299S0
G1 X0.786S1000
G1 X4.39S0
G1 X0.831S1000
G1 X0.706S0
G1 X0.769S1000
G1 X1.979S0
G1 X0.831S1000
G1 X0.706S0
G1 X0.768S1000
G1 X2.111S0
G1 X0.793S1000
G1 X2.293S0
G1 X0.786S1000
G1 X1.025S0
G1 X0.793S1000
G1 X2.293S0
G1 X0.786S1000
G1 X1.25S0
G1 X-0.023Y-0.1S0
G1 X-1.25S0
G1 X-0.786S1000
G1 X-2.247S0
G1 X-0.795S1000
G1 X-1.068S0
G1 X-0.786S1000
G1 X-2.247S0
G1 X-0.796S1000
G1 X-2.132S0
G1 X-0.768S1000
G1 X-0.556S0
G1 X-0.981S1000
G1 X-1.979S0
G1 X-0.769S1000
G1 X-0.555S0
G1 X-0.982S1000
G1 X-4.412S0
G1 X-0.786S1000
G1 X-2.255S0
G1 X-0.788S1000
G1 X-1.067S0
G1 X-0.787S1000
G1 X-2.254S0
G1 X-0.788S1000
G1 X-1.068S0
G1 X-0.786S1000
G1 X-2.255S0
G1 X-0.788S1000
G1 X-1.005S0
G1 X-0.792S1000
G1 X-2.386S0
G1 X-0.795S1000
G1 X-106.595S0
G1 X-0.785S1000
G1 X-2.239S0
G1 X-0.796S1000
G1 X-1.076S0
G1 X-0.786S1000
G1 X-2.238S0
G1 X-0.796S1000
G1 X-2.136S0
G1 X-0.769S1000
G1 X-0.53S0
G1 X-1.007S1000
G1 X-1.463S0
G1 X-0.791S1000
G1 X-2.387S0
G1 X-0.794S1000
G1 X-3.878S0
G1 X-0.786S1000
G1 X-2.246S0
G1 X-0.788S1000
G1 X-1.077S0
G1 X-0.785S1000
G1 X-2.246S0
G1 X-0.788S1000
G1 X-1.077S0
G1 X-0.786S1000
G1 X-2.246S0
G1 X-0.788S1000
G1 X-1.243S0
G1 X-0.794S1000
G1 X-1.25S0
G1 X-2.549Y-0.1S0
G1 X1.25S0
G1 X0.418S1000
G1 X2.142S0
G1 X0.79S1000
G1 X1.261S0
G1 X0.789S1000
G1 X2.198S0
G1 X0.779S1000
G1 X1.131S0
G1 X0.788S1000
G1 X2.198S0
G1 X0.779S1000
G1 X1.131S0
G1 X0.789S1000
G1 X2.198S0
G1 X0.779S1000
G1 X3.921S0
G1 X0.787S1000
G1 X2.386S0
G1 X0.788S1000
G1 X1.46S0
G1 X1.158S1000
G1 X0.379S0
G1 X0.769S1000
G1 X2.161S0
G1 X0.794S1000
G1 X2.192S0
G1 X0.78S1000
G1 X1.13S0
G1 X0.795S1000
G1 X2.192S0
G1 X0.779S1000
G1 X106.637S0
G1 X0.789S1000
G1 X2.389S0
G1 X0.787S1000
G1 X1.025S0
G1 X0.789S1000
G1 X2.206S0
G1 X0.78S1000
G1 X1.122S0
G1 X0.788S1000
G1 X2.206S0
G1 X0.781S1000
G1 X1.121S0
G1 X0.789S1000
G1 X2.206S0
G1 X0.78S1000
G1 X4.441S0
G1 X1.132S1000
G1 X0.405S0
G1 X0.769S1000
G1 X1.979S0
G1 X1.132S1000
G1 X0.405S0
G1 X0.768S1000
G1 X2.157S0
G1 X0.794S1000
G1 X2.201S0
G1 X0.78S1000
G1 X1.122S0
G1 X0.794S1000
G1 X2.2S0
G1 X0.78S1000
G1 X1.25S0
G1 X-0.028Y-0.1S0
G1 X-1.25S0
G1 X-0.78S1000
G1 X-2.149S0
G1 X-0.792S1000
G1 X-1.176S0
G1 X-0.78S1000
G1 X-2.148S0
G1 X-0.793S1000
G1 X-2.182S0
G1 X-0.768S1000
G1 X-0.271S0
G1 X-1.266S1000
G1 X-1.979S0
G1 X-0.769S1000
G1 X-0.271S0
G1 X-1.266S1000
G1 X-4.47S0
G1 X-0.78S1000
G1 X-2.152S0
G1 X-0.789S1000
G1 X-1.175S0
G1 X-0.78S1000
G1 X-2.152S0
G1 X-0.789S1000
G1 X-1.176S0
G1 X-0.78S1000
G1 X-2.152S0
G1 X-0.789S1000
G1 X-1.058S0
G1 X-0.788S1000
G1 X-2.374S0
G1 X-0.781S1000
G1 X-106.68S0
G1 X-0.781S1000
G1 X-2.138S0
G1 X-0.793S1000
G1 X-1.184S0
G1 X-0.781S1000
G1 X-2.139S0
G1 X-0.792S1000
G1 X-2.186S0
G1 X-0.769S1000
G1 X-0.249S0
G1 X-1.288S1000
G1 X-1.468S0
G1 X-0.789S1000
G1 X-2.37S0
G1 X-0.78S1000
G1 X-3.964S0
G1 X-0.781S1000
G1 X-2.142S0
G1 X-0.789S1000
G1 X-1.185S0
G1 X-0.78S1000
G1 X-2.142S0
G1 X-0.789S1000
G1 X-1.185S0
G1 X-0.781S1000
G1 X-2.142S0
G1 X-0.789S1000
G1 X-1.284S0
G1 X-0.788S1000
G1 X-2.128S0
G1 X-0.791S1000
G1 X-1.25S0
G1 X0.023Y-0.1S0
G1 X1.25S0
G1 X0.792S1000
G1 X2.094S0
G1 X0.796S1000
G1 X1.311S0
G1 X0.79S1000
G1 X2.083S0
G1 X0.785S1000
G1 X1.239S0
G1 X0.789S1000
G1 X2.083S0
G1 X0.786S1000
G1 X1.238S0
G1 X0.79S1000
G1 X2.083S0
G1 X0.785S1000
G1 X4.006S0
G1 X0.798S1000
G1 X2.323S0
G1 X0.797S1000
G1 X1.637S0
G1 X1.252S1000
G1 X0.124S0
G1 X0.769S1000
G1 X2.211S0
G1 X0.791S1000
G1 X2.082S0
G1 X0.785S1000
G1 X1.238S0
G1 X0.791S1000
G1 X2.082S0
G1 X0.785S1000
G1 X106.723S0
G1 X0.795S1000
G1 X2.333S0
G1 X0.793S1000
G1 X1.091S0
G1 X0.79S1000
G1 X2.093S0
G1 X0.784S1000
G1 X1.23S0
G1 X0.789S1000
G1 X2.093S0
G1 X0.785S1000
G1 X1.229S0
G1 X0.79S1000
G1 X2.093S0
G1 X0.784S1000
G1 X4.628S0
G1 X1.262S1000
G1 X0.146S0
G1 X0.769S1000
G1 X2.107S0
G1 X1.263S1000
G1 X0.146S0
G1 X0.768S1000
G1 X2.207S0
G1 X0.791S1000
G1 X2.092S0
G1 X0.784S1000
G1 X1.23S0
G1 X0.791S1000
G1 X2.091S0
G1 X0.785S1000
G1 X1.25S0
G1 X-0.03Y-0.1S0
G1 X-1.25S0
G1 X-0.788S1000
G1 X-2.029S0
G1 X-0.794S1000
G1 X-1.286S0
G1 X-0.788S1000
G1 X-2.029S0
G1 X-0.794S1000
G1 X-2.233S0
G1 X-0.768S1000
G1 X-0.021S0
G1 X-1.197S1000
G1 X-2.298S0
G1 X-0.769S1000
G1 X-0.02S0
G1 X-1.197S1000
G1 X-4.848S0
G1 X-0.788S1000
G1 X-2.03S0
G1 X-0.794S1000
G1 X-1.285S0
G1 X-0.788S1000
G1 X-2.029S0
G1 X-0.794S1000
G1 X-1.285S0
G1 X-0.788S1000
G1 X-2.03S0
G1 X-0.794S1000
G1 X-1.132S0
G1 X-0.806S1000
G1 X-2.271S0
G1 X-0.815S1000
G1 X-106.769S0
G1 X-0.786S1000
G1 X-2.016S0
G1 X-0.795S1000
G1 X-1.299S0
G1 X-0.787S1000
G1 X-2.016S0
G1 X-0.795S1000
G1 X-2.239S0
G1 X-1.954S1000
G1 X-1.846S0
G1 X-0.807S1000
G1 X-2.261S0
G1 X-0.817S1000
G1 X-4.053S0
G1 X-0.786S1000
G1 X-2.017S0
G1 X-0.795S1000
G1 X-1.298S0
G1 X-0.787S1000
G1 X-2.016S0
G1 X-0.795S1000
G1 X-1.299S0
G1 X-0.786S1000
G1 X-2.017S0
G1 X-0.795S1000
G1 X-1.356S0
G1 X-0.794S1000
G1 X-2.043S0
G1 X-0.805S1000
G1 X-1.25S0
G1 X0.024Y-0.1S0
G1 X1.25S0
G1 X0.82S1000
G1 X1.971S0
G1 X0.811S1000
G1 X1.411S0
G1 X0.8S1000
G1 X1.939S0
G1 X0.778S1000
G1 X1.379S0
G1 X0.801S1000
G1 X1.939S0
G1 X0.778S1000
G1 X1.379S0
G1 X0.8S1000
G1 X1.939S0
G1 X0.778S1000
G1 X4.133S0
G1 X0.814S1000
G1 X2.187S0
G1 X0.826S1000
G1 X2.043S0
G1 X1.777S1000
G1 X2.277S0
G1 X0.801S1000
G1 X1.939S0
G1 X0.778S1000
G1 X1.379S0
G1 X0.801S1000
G1 X1.938S0
G1 X0.779S1000
G1 X106.844S0
G1 X0.814S1000
G1 X2.203S0
G1 X0.82S1000
G1 X1.191S0
G1 X0.8S1000
G1 X1.952S0
G1 X0.78S1000
G1 X1.365S0
G1 X0.8S1000
G1 X1.952S0
G1 X0.779S1000
G1 X1.365S0
G1 X0.8S1000
G1 X1.952S0
G1 X0.78S1000
G1 X5.075S0
G1 X1.801S1000
G1 X2.483S0
G1 X1.801S1000
G1 X2.271S0
G1 X0.8S1000
G1 X1.952S0
G1 X0.78S1000
G1 X1.365S0
G1 X0.8S1000
G1 X1.952S0
G1 X0.779S1000
G1 X1.25S0
G1 X-0.041Y-0.1S0
G1 X-1.25S0
G1 X-0.79S1000
G1 X-1.856S0
G1 X-0.806S1000
G1 X-1.445S0
G1 X-0.79S1000
G1 X-1.856S0
G1 X-0.806S1000
G1 X-2.309S0
G1 X-1.659S1000
G1 X-2.625S0
G1 X-1.659S1000
G1 X-5.259S0
G1 X-0.79S1000
G1 X-1.856S0
G1 X-0.806S1000
G1 X-1.444S0
G1 X-0.79S1000
G1 X-1.856S0
G1 X-0.806S1000
G1 X-1.445S0
G1 X-0.789S1000
G1 X-1.857S0
G1 X-0.806S1000
G1 X-1.252S0
G1 X-0.846S1000
G1 X-2.093S0
G1 X-0.837S1000
G1 X-106.924S0
G1 X-0.792S1000
G1 X-1.839S0
G1 X-0.807S1000
G1 X-1.458S0
G1 X-0.793S1000
G1 X-1.839S0
G1 X-0.807S1000
G1 X-2.315S0
G1 X-1.635S1000
G1 X-2.213S0
G1 X-0.847S1000
G1 X-2.073S0
G1 X-0.841S1000
G1 X-4.212S0
G1 X-0.792S1000
G1 X-1.84S0
G1 X-0.806S1000
G1 X-1.459S0
G1 X-0.792S1000
G1 X-1.839S0
G1 X-0.807S1000
G1 X-1.458S0
G1 X-0.792S1000
G1 X-1.84S0
G1 X-0.806S1000
G1 X-1.48S0
G1 X-0.819S1000
G1 X-1.876S0
G1 X-0.834S1000
G1 X-1.25S0
G1 X0.042Y-0.1S0
G1 X1.25S0
G1 X0.851S1000
G1 X1.762S0
G1 X0.838S1000
G1 X1.559S0
G1 X0.836S1000
G1 X1.703S0
G1 X0.814S1000
G1 X1.543S0
G1 X0.837S1000
G1 X1.702S0
G1 X0.814S1000
G1 X1.544S0
G1 X0.836S1000
G1 X1.703S0
G1 X0.814S1000
G1 X4.292S0
G1 X0.868S1000
G1 X1.94S0
G1 X0.873S1000
G1 X2.397S0
G1 X1.493S1000
G1 X2.358S0
G1 X0.837S1000
G1 X1.703S0
G1 X0.814S1000
G1 X1.543S0
G1 X0.836S1000
G1 X1.703S0
G1 X0.814S1000
G1 X107.004S0
G1 X0.864S1000
G1 X1.964S0
G1 X0.867S1000
G1 X1.336S0
G1 X0.832S1000
G1 X1.73S0
G1 X0.807S1000
G1 X1.527S0
G1 X0.833S1000
G1 X1.73S0
G1 X0.807S1000
G1 X1.527S0
G1 X0.832S1000
G1 X1.73S0
G1 X0.807S1000
G1 X5.443S0
G1 X1.517S1000
G1 X2.767S0
G1 X1.517S1000
G1 X2.349S0
G1 X0.833S1000
G1 X1.73S0
G1 X0.807S1000
G1 X1.527S0
G1 X0.832S1000
G1 X1.73S0
G1 X0.808S1000
G1 X1.25S0
G1 X-0.042Y-0.1S0
G1 X-1.25S0
G1 X-0.847S1000
G1 X-1.57S0
G1 X-0.856S1000
G1 X-1.623S0
G1 X-0.847S1000
G1 X-1.571S0
G1 X-0.855S1000
G1 X-2.405S0
G1 X-1.375S1000
G1 X-2.909S0
G1 X-1.375S1000
G1 X-5.626S0
G1 X-0.847S1000
G1 X-1.571S0
G1 X-0.855S1000
G1 X-1.624S0
G1 X-0.846S1000
G1 X-1.571S0
G1 X-0.856S1000
G1 X-1.623S0
G1 X-0.847S1000
G1 X-1.571S0
G1 X-0.855S1000
G1 X-1.433S0
G1 X-0.901S1000
G1 X-1.81S0
G1 X-0.904S1000
G1 X-107.084S0
G1 X-0.853S1000
G1 X-1.544S0
G1 X-0.859S1000
G1 X-1.64S0
G1 X-0.853S1000
G1 X-1.544S0
G1 X-0.859S1000
G1 X-2.414S0
G1 X-1.355S1000
G1 X-2.578S0
G1 X-0.911S1000
G1 X-1.773S0
G1 X-0.914S1000
G1 X-4.374S0
G1 X-0.853S1000
G1 X-1.544S0
G1 X-0.859S1000
G1 X-1.641S0
G1 X-0.853S1000
G1 X-1.543S0
G1 X-0.859S1000
G1 X-1.641S0
G1 X-0.853S1000
G1 X-1.544S0
G1 X-0.859S1000
G1 X-1.656S0
G1 X-0.869S1000
G1 X-1.609S0
G1 X-0.888S1000
G1 X-1.25S0
G1 X0.061Y-0.1S0
G1 X1.25S0
G1 X0.922S1000
G1 X1.419S0
G1 X0.909S1000
G1 X1.766S0
G1 X0.914S1000
G1 X1.324S0
G1 X0.908S1000
G1 X1.751S0
G1 X0.914S1000
G1 X1.324S0
G1 X0.907S1000
G1 X1.751S0
G1 X0.914S1000
G1 X1.324S0
G1 X0.908S1000
G1 X4.496S0
G1 X0.957S1000
G1 X1.559S0
G1 X0.958S1000
G1 X2.743S0
G1 X1.247S1000
G1 X2.469S0
G1 X0.914S1000
G1 X1.324S0
G1 X0.908S1000
G1 X1.751S0
G1 X0.913S1000
G1 X1.325S0
G1 X0.907S1000
G1 X107.204S0
G1 X0.95S1000
G1 X1.595S0
G1 X0.951S1000
G1 X1.542S0
G1 X0.902S1000
G1 X1.365S0
G1 X0.898S1000
G1 X1.732S0
G1 X0.901S1000
G1 X1.365S0
G1 X0.898S1000
G1 X1.732S0
G1 X0.902S1000
G1 X1.365S0
G1 X0.898S1000
G1 X5.789S0
G1 X1.265S1000
G1 X3.019S0
G1 X1.265S1000
G1 X2.46S0
G1 X0.901S1000
G1 X1.366S0
G1 X0.898S1000
G1 X1.732S0
G1 X0.901S1000
G1 X1.365S0
G1 X0.898S1000
G1 X1.25S0
G1 X-0.055Y-0.1S0
G1 X-1.25S0
G1 X-0.98S1000
G1 X-1.1S0
G1 X-0.966S1000
G1 X-1.85S0
G1 X-0.981S1000
G1 X-1.099S0
G1 X-0.967S1000
G1 X-2.523S0
G1 X-1.156S1000
G1 X-3.128S0
G1 X-1.157S1000
G1 X-5.952S0
G1 X-0.98S1000
G1 X-1.1S0
G1 X-0.967S1000
G1 X-1.85S0
G1 X-0.98S1000
G1 X-1.1S0
G1 X-0.966S1000
G1 X-1.85S0
G1 X-0.98S1000
G1 X-1.1S0
G1 X-0.967S1000
G1 X-1.667S0
G1 X-1.029S1000
G1 X-1.326S0
G1 X-1.013S1000
G1 X-107.326S0
G1 X-0.997S1000
G1 X-1.05S0
G1 X-0.976S1000
G1 X-1.873S0
G1 X-0.998S1000
G1 X-1.05S0
G1 X-0.976S1000
G1 X-2.535S0
G1 X-1.138S1000
G1 X-2.914S0
G1 X-1.044S1000
G1 X-1.263S0
G1 X-1.039S1000
G1 X-4.618S0
G1 X-0.998S1000
G1 X-1.05S0
G1 X-0.975S1000
G1 X-1.874S0
G1 X-0.997S1000
G1 X-1.05S0
G1 X-0.976S1000
G1 X-1.873S0
G1 X-0.998S1000
G1 X-1.05S0
G1 X-0.975S1000
G1 X-1.893S0
G1 X-0.985S1000
G1 X-1.146S0
G1 X-0.994S1000
G1 X-1.25S0
G1 X0.065Y-0.1S0
G1 X1.25S0
G1 X1.156S1000
G1 X0.692S0
G1 X1.138S1000
G1 X2.042S0
G1 X1.12S1000
G1 X0.609S0
G1 X1.145S1000
G1 X2.023S0
G1 X1.119S1000
G1 X0.609S0
G1 X1.146S1000
G1 X2.022S0
G1 X1.12S1000
G1 X0.609S0
G1 X1.145S1000
G1 X4.759S0
G1 X1.232S1000
G1 X0.754S0
G1 X1.221S1000
G1 X3.094S0
G1 X1.03S1000
G1 X2.611S0
G1 X1.119S1000
G1 X0.61S0
G1 X1.145S1000
G1 X2.023S0
G1 X1.119S1000
G1 X0.609S0
G1 X1.146S1000
G1 X107.466S0
G1 X1.18S1000
G1 X0.884S0
G1 X1.169S1000
G1 X1.811S0
G1 X1.093S1000
G1 X0.691S0
G1 X1.115S1000
G1 X1.997S0
G1 X1.094S1000
G1 X0.69S0
G1 X1.116S1000
G1 X1.997S0
G1 X1.093S1000
G1 X0.691S0
G1 X1.115S1000
G1 X6.133S0
G1 X1.048S1000
G1 X3.236S0
G1 X1.048S1000
G1 X2.599S0
G1 X1.093S1000
G1 X0.69S0
G1 X1.116S1000
G1 X1.997S0
G1 X1.094S1000
G1 X0.69S0
G1 X1.116S1000
G1 X1.25S0
G1 X-0.076Y-0.1S0
G1 X-1.25S0
G1 X-2.748S1000
G1 X-2.148S0
G1 X-2.749S1000
G1 X-2.674S0
G1 X-0.946S1000
G1 X-3.338S0
G1 X-0.946S1000
G1 X-6.31S0
G1 X-2.749S1000
G1 X-2.148S0
G1 X-2.748S1000
G1 X-2.148S0
G1 X-2.749S1000
G1 X-1.973S0
G1 X-3.063S1000
G1 X-107.629S0
G1 X-2.718S1000
G1 X-2.178S0
G1 X-2.719S1000
G1 X-2.687S0
G1 X-0.932S1000
G1 X-3.279S0
G1 X-3.03S1000
G1 X-4.928S0
G1 X-2.718S1000
G1 X-2.178S0
G1 X-2.719S1000
G1 X-2.178S0
G1 X-2.718S1000
G1 X-2.201S0
G1 X-2.812S1000
G1 X-1.25S0
G1 X0.093Y-0.1S0
G1 X1.25S0
G1 X2.622S1000
G1 X2.398S0
G1 X2.522S1000
G1 X2.375S0
G1 X2.522S1000
G1 X2.374S0
G1 X2.522S1000
G1 X5.129S0
G1 X2.828S1000
G1 X3.459S0
G1 X0.849S1000
G1 X2.788S0
G1 X2.522S1000
G1 X2.375S0
G1 X2.522S1000
G1 X107.829S0
G1 X2.866S1000
G1 X2.163S0
G1 X2.555S1000
G1 X2.341S0
G1 X2.556S1000
G1 X2.341S0
G1 X2.555S1000
G1 X6.489S0
G1 X0.863S1000
G1 X3.422S0
G1 X0.862S1000
G1 X2.771S0
G1 X2.556S1000
G1 X2.341S0
G1 X2.555S1000
G1 X1.25S0
G1 X-0.11Y-0.1S0
G1 X-1.25S0
G1 X-2.344S1000
G1 X-2.552S0
G1 X-2.345S1000
G1 X-2.872S0
G1 X-0.779S1000
G1 X-3.505S0
G1 X-0.78S1000
G1 X-6.682S0
G1 X-2.345S1000
G1 X-2.551S0
G1 X-2.345S1000
G1 X-2.552S0
G1 X-2.345S1000
G1 X-2.38S0
G1 X-2.643S1000
G1 X-108.05S0
G1 X-2.307S1000
G1 X-2.59S0
G1 X-2.306S1000
G1 X-2.889S0
G1 X-0.765S1000
G1 X-3.66S0
G1 X-2.605S1000
G1 X-5.35S0
G1 X-2.306S1000
G1 X-2.59S0
G1 X-2.306S1000
G1 X-2.591S0
G1 X-2.306S1000
G1 X-2.618S0
G1 X-2.385S1000
G1 X-1.25S0
G1 X0.155Y-0.1S0
G1 X1.25S0
G1 X2.092S1000
G1 X2.909S0
G1 X2.018S1000
G1 X2.878S0
G1 X2.018S1000
G1 X2.879S0
G1 X2.018S1000
G1 X5.648S0
G1 X2.298S1000
G1 X3.887S0
G1 X0.682S1000
G1 X3.042S0
G1 X2.018S1000
G1 X2.878S0
G1 X2.018S1000
G1 X108.335S0
G1 X2.357S1000
G1 X2.659S0
G1 X2.074S1000
G1 X2.823S0
G1 X2.073S1000
G1 X2.823S0
G1 X2.074S1000
G1 X6.895S0
G1 X0.696S1000
G1 X3.588S0
G1 X0.696S1000
G1 X3.014S0
G1 X2.074S1000
G1 X2.822S0
G1 X2.074S1000
G1 X1.25S0
G1 X-0.163Y-0.1S0
G1 X-1.25S0
G1 X-1.745S1000
G1 X-3.151S0
G1 X-1.746S1000
G1 X-3.179S0
G1 X-0.613S1000
G1 X-3.671S0
G1 X-0.613S1000
G1 X-7.141S0
G1 X-1.745S1000
G1 X-3.152S0
G1 X-1.745S1000
G1 X-3.151S0
G1 X-1.745S1000
G1 X-2.988S0
G1 X-2.003S1000
G1 X-108.698S0
G1 X-1.68S1000
G1 X-3.217S0
G1 X-1.68S1000
G1 X-3.207S0
G1 X-0.603S1000
G1 X-4.142S0
G1 X-1.931S1000
G1 X-6.012S0
G1 X-1.68S1000
G1 X-3.216S0
G1 X-1.68S1000
G1 X-3.217S0
G1 X-1.68S1000
G1 X-3.25S0
G1 X-1.738S1000
G1 X-1.25S0
G1 X0.258Y-0.1S0
G1 X1.25S0
G1 X1.22S1000
G1 X3.776S0
G1 X1.163S1000
G1 X3.733S0
G1 X1.164S1000
G1 X3.733S0
G1 X1.163S1000
G1 X6.555S0
G1 X1.382S1000
G1 X4.456S0
G1 X0.546S1000
G1 X3.472S0
G1 X1.164S1000
G1 X3.733S0
G1 X1.164S1000
G1 X109.221S0
G1 X1.496S1000
G1 X3.469S0
G1 X1.267S1000
G1 X3.63S0
G1 X1.267S1000
G1 X3.629S0
G1 X1.267S1000
G1 X7.43S0
G1 X0.556S1000
G1 X3.729S0
G1 X0.555S1000
G1 X3.426S0
G1 X1.267S1000
G1 X3.629S0
G1 X1.268S1000
G1 X1.25S0
G1 X-0.626Y-0.1S0
G1 X-1.25S0
G1 X-0.183S1000
G1 X-4.714S0
G1 X-0.183S1000
G1 X-3.884S0
G1 X-0.497S1000
G1 X-3.787S0
G1 X-0.498S1000
G1 X-8.113S0
G1 X-0.184S1000
G1 X-4.712S0
G1 X-0.184S1000
G1 X-4.713S0
G1 X-0.184S1000
G1 X-4.613S0
G1 X-0.314S1000
G1 X-1.25S0
G90
M9
G1 S0
M5
G90
G0 X100 Y100
M2
Stream completed in 10:09
[MSG:Pgm End]
Project file saved as test square.
JohnJohn
(John Johnson)
March 9, 2022, 4:09pm
16
This test square appears to have dozens of S0 ‘spindle-off’ motion commands. is cut-tabs still enabled? Can you shut that off and re-test? Once all the power changes are out of this the g-code should be a few lines. There’s an F at the beginning of the G-code stream that will tell me what speed its being commanded to engrave at.
this is with tabs right after i press start
Waiting for connection…
ok
ok
y limit trigged
MPos:0.000000,0.000000,0.000000
ok
[XTool D1:ver 40.30.002.01 B1]
Project loaded in 1 milliseconds
Starting stream
M106 S0
G00 G17 G40 G21 G54
G90
M4
M9
G0 X15.33Y29.596
Layer outward kerf
G1 X15.304S1000F3000
G1 X15.279Y29.628
G1 X15.265Y29.659
G1 Y29.675
G1 Y95.203
G0 Y95.303
G1 Y160.831
G1 Y160.856
G1 X15.279Y160.878
G1 X15.301Y160.899
G1 X15.322
G1 X15.344Y160.911
G1 X80.872
G0 X80.972
G1 X146.5
G1 X146.529
G1 X146.542Y160.899
G1 X146.553
G1 X146.566Y160.876
G1 Y160.858
G1 X146.58Y160.831
G1 Y95.303
G0 Y95.203
G1 Y29.675
G1 Y29.64
G1 X146.555Y29.618
G1 X146.537Y29.605
G1 X146.521
G1 X146.505
G1 X80.972
G0 X80.872
G1 X15.33
M9
G0 X19.702Y33.968
Layer InnerLine
G1 X19.676F2900
G1 X19.658Y33.991
G1 X19.64Y34.02
G1 Y34.047
G1 Y95.203
G0 Y95.303
G1 Y156.468
G1 Y156.494
G1 X19.656Y156.513
G1 X19.673Y156.527
G1 X19.694
G1 X19.716Y156.539
G1 X80.872
G0 X80.972
G1 X142.128
G1 X142.163
G1 X142.189Y156.511
G1 X142.203Y156.481
G1 Y156.459
G1 Y95.303
G0 Y95.203
G1 Y34.033
G1 Y34.012
G1 X142.187Y33.994
G1 X142.165Y33.977
G1 X142.15
G1 X142.133
G1 X80.972
G0 X80.872
G1 X19.702
M9
G0 X24.074Y38.34
Layer C02
G1 X24.043Y38.353F2800
G1 X24.02Y38.376
G1 X24.009Y38.402
G1 Y38.419
G1 Y95.003
G0 Y95.503
G1 Y152.101
G1 Y152.127
G1 X24.036Y152.149
G1 X24.05
G1 X24.065Y152.164
G1 X24.087
G1 X80.672
G0 X81.172
G1 X137.77
G1 X137.791
G1 X137.805Y152.15
G1 X137.817Y152.139
G1 X137.83Y152.115
G1 Y152.087
G1 Y95.503
G0 Y95.003
G1 Y38.405
G1 Y38.379
G1 X137.807Y38.358
G1 X137.793
G1 X137.778Y38.343
G1 X137.761
G1 X81.172
G0 X80.672
G1 X24.074
M9
G0 X28.442Y42.713
Layer InnerCut
G1 X28.419F2700
G1 X28.402Y42.735
G1 X28.384Y42.763
G1 Y42.791
G1 Y95.203
G0 Y95.303
G1 Y147.729
G1 Y147.745
G1 X28.4Y147.769
G1 X28.427Y147.788
G1 X28.443
G1 X28.459
G1 X80.872
G0 X80.972
G1 X133.384
G1 X133.414
G1 X133.449Y147.762
G1 Y147.748
G1 X133.464Y147.715
G1 Y95.303
G0 Y95.203
G1 Y42.781
G1 Y42.756
G1 X133.44Y42.733
G1 X133.424Y42.722
G1 X133.411
G1 X133.384Y42.711
G1 X80.972
G0 X80.872
G1 X28.459
G1 X28.442
M9
G0 X32.756Y47.135
Layer FlexCut
G1 Y47.163F2600
G1 Y95.203
G0 Y95.303
G1 Y143.352
G1 Y143.368
G1 X32.768Y143.393
G1 X32.784Y143.408
G1 X32.809Y143.42
G1 X32.831
G1 X80.872
G0 X80.972
G1 X129.021
G1 X129.07Y143.399
G1 X129.086Y143.373
G1 Y143.344
G1 Y95.303
G0 Y95.203
G1 Y47.149
G1 Y47.128
G1 X129.068Y47.105
G1 X129.055Y47.095
G1 X129.037
G1 X129.018Y47.083
G1 X80.972
G0 X80.872
G1 X32.817
G1 X32.802
G1 X32.774Y47.107
G1 X32.756Y47.135
M9
G0 X37.138Y51.487
Layer Raster1
G1 X37.125Y51.518F2500
G1 Y51.534
G1 Y95.203
G0 Y95.303
G1 Y138.972
G1 Y138.996
G1 X37.14Y139.021
G1 X37.161Y139.04
G1 X37.181
G1 X37.203Y139.052
G1 X80.872
G0 X80.972
G1 X124.64
G1 X124.66
G1 X124.675
G1 X124.693Y139.03
G1 X124.708Y139.014
G1 X124.72Y138.972
G1 Y95.303
G0 Y95.203
G1 Y51.525
G1 Y51.5
G1 X124.698Y51.479
G1 X124.678Y51.464
G1 X124.662
G1 X124.646
G1 X80.972
G0 X80.872
G1 X37.189
G1 X37.158
G1 X37.138Y51.487
M9
G0 X41.495Y55.906
Layer Raster2
G1 Y95.203F2400
G0 Y95.303
G1 Y134.614
G1 Y134.63
G1 X41.515Y134.653
G1 X41.53Y134.666
G1 X41.558Y134.678
G1 X41.575
G1 X80.872
G0 X80.972
G1 X120.278
G1 X120.313Y134.666
G1 X120.333Y134.647
G1 X120.344Y134.627
G1 Y134.6
G1 Y95.303
G0 Y95.203
G1 Y55.893
G1 Y55.866
G1 X120.32Y55.845
G1 X120.301Y55.833
G1 X120.274
G1 X80.972
G0 X80.872
G1 X41.575
G1 X41.55
G1 X41.53
G1 X41.51Y55.859
G1 X41.497Y55.89
G1 Y55.906
M9
G0 X45.932Y60.2
Layer Raster3
G1 X45.917F2300
G1 X45.889Y60.223
G1 X45.876Y60.241
G1 Y60.262
G1 Y60.278
G1 Y95.203
G0 Y95.303
G1 Y130.228
G1 Y130.253
G1 Y130.273
G1 X45.891Y130.286
G1 X45.904
G1 X45.919Y130.303
G1 X45.947
G1 X80.872
G0 X80.972
G1 X115.896
G1 X115.916
G1 X115.931
G1 X115.946Y130.291
G1 X115.967Y130.266
G1 Y130.25
G1 Y130.228
G1 Y95.303
G0 Y95.203
G1 Y60.27
G1 Y60.243
G1 X115.956Y60.225
G1 X115.944Y60.214
G1 X115.918Y60.201
G1 X115.896
G1 X80.972
G0 X80.872
G1 X45.947
G1 X45.932
M9
G0 X50.286Y64.577
Layer Raster4
G1 X50.265Y64.591F2200
G1 X50.251Y64.608
G1 X50.24Y64.634
G1 Y64.65
G1 Y95.203
G0 Y95.303
G1 Y125.856
G1 Y125.881
G1 Y125.896
G1 X50.263Y125.914
G1 X50.276Y125.924
G1 X50.297
G1 X50.319Y125.936
G1 X80.872
G0 X80.972
G1 X111.525
G1 X111.56
G1 X111.582Y125.912
G1 X111.598Y125.889
G1 Y125.873
G1 Y125.856
G1 Y95.303
G0 Y95.203
G1 Y64.65
G1 Y64.62
G1 X111.588Y64.601
G1 X111.562Y64.58
G1 X111.547
G1 X111.53
G1 X80.972
G0 X80.872
G1 X50.305
G1 X50.286
M9
G0 X54.618Y68.99
Layer C09
G1 Y69F2100
G1 Y69.022
G1 Y95.203
G0 Y95.303
G1 Y121.504
G1 Y121.514
G1 X54.631Y121.538
G1 X54.648Y121.552
G1 X54.663
G1 X54.69Y121.564
G1 X80.872
G0 X80.972
G1 X107.153
G1 X107.172
G1 X107.202Y121.547
G1 X107.214Y121.536
G1 X107.228Y121.512
G1 Y121.484
G1 Y95.303
G0 Y95.203
G1 Y69.014
G1 Y68.992
G1 X107.212Y68.969
G1 X107.19Y68.951
G1 X107.175
G1 X107.158
G1 X80.972
G0 X80.872
G1 X54.682
G1 X54.656
G1 X54.629Y68.97
G1 X54.618Y68.99
M9
G0 X156.433Y29.061
Layer C10
G1 Y29.082F2000
G1 Y29.098
G1 Y94.626
G0 Y94.726
G1 Y160.264
G1 Y160.299
G1 X156.452Y160.315
G1 X156.476Y160.329
G1 X156.503
G1 X222.031
G0 X222.131
G1 X287.667
G1 X287.694
G1 X287.717Y160.31
G1 Y160.297
G1 X287.739Y160.254
G1 Y94.726
G0 Y94.626
G1 Y29.098
G1 Y29.073
G1 X287.725Y29.054
G1 X287.71Y29.037
G1 X287.696
G1 X287.681Y29.021
G1 X287.659
G1 X222.131
G0 X222.031
G1 X156.503
G1 X156.473
G1 X156.446Y29.042
G1 X156.433Y29.061
M9
G0 X160.798Y33.448
Layer C11
G1 Y33.47F1900
G1 Y94.626
G0 Y94.726
G1 Y155.882
G1 Y155.907
G1 X160.819Y155.94
G1 X160.833
G1 X160.851Y155.957
G1 X160.875
G1 X222.031
G0 X222.131
G1 X283.287
G1 X283.307
G1 X283.327
G1 X283.352Y155.929
G1 Y155.906
G1 X283.367Y155.882
G1 Y94.726
G0 Y94.626
G1 Y33.47
G1 Y33.44
G1 X283.347Y33.417
G1 X283.33Y33.402
G1 X283.312
G1 X283.293Y33.39
G1 X222.131
G0 X222.031
G1 X160.867
G1 X160.84
G1 X160.826Y33.407
G1 X160.81Y33.423
G1 X160.798Y33.448
M9
G0 X165.232Y37.764
Layer C12
G1 X165.217F1800
G1 X165.193Y37.782
G1 X165.176Y37.804
G1 Y37.825
G1 Y37.842
G1 Y94.626
G0 Y94.726
G1 Y151.519
G1 Y151.55
G1 X165.191Y151.568
G1 X165.225Y151.587
G1 X165.247
G1 X222.031
G0 X222.131
G1 X278.915
G1 X278.955
G1 X278.977Y151.562
G1 X278.99Y151.538
G1 Y151.51
G1 Y94.726
G0 Y94.626
G1 Y37.842
G1 Y37.817
G1 X278.978Y37.792
G1 X278.966Y37.781
G1 X278.953
G1 X278.937Y37.766
G1 X278.921
G1 X222.131
G0 X222.031
G1 X165.247
G1 X165.232
M9
G0 X169.589Y42.14
Layer Line Cut
G1 X169.569Y42.151F1700
G1 X169.551Y42.171
G1 X169.54Y42.197
G1 Y42.214
G1 Y94.626
G0 Y94.726
G1 Y147.147
G1 Y147.178
G1 X169.576Y147.206
G1 X169.597
G1 X169.619Y147.219
G1 X222.031
G0 X222.131
G1 X274.543
G1 X274.576Y147.209
G1 X274.605Y147.19
G1 X274.616Y147.171
G1 Y147.138
G1 Y94.726
G0 Y94.626
G1 Y42.195
G1 Y42.179
G1 X274.601Y42.158
G1 X274.571Y42.139
G1 X274.543
G1 X222.131
G0 X222.031
G1 X169.61
G1 X169.589
M9
G0 X173.981Y46.506
Layer C14
G1 X173.95Y46.516F1600
G1 X173.933Y46.53
G1 X173.923Y46.543
G1 Y46.564
G1 X173.91Y46.586
G1 Y94.626
G0 Y94.726
G1 Y142.78
G1 X173.921Y142.803
G1 X173.935Y142.824
G1 X173.953Y142.837
G1 X173.99
G1 X222.031
G0 X222.131
G1 X270.171
G1 X270.201
G1 X270.239Y142.809
G1 Y142.788
G1 X270.251Y142.767
G1 Y94.726
G0 Y94.626
G1 Y46.586
G1 Y46.571
G1 Y46.556
G1 X270.234Y46.536
G1 X270.22Y46.523
G1 X270.204Y46.513
G1 X270.177
G1 X222.131
G0 X222.031
G1 X173.981
M9
G0 X178.313Y50.895
Layer C15
G1 X178.294Y50.915F1500
G1 Y50.936
G1 X178.282Y50.958
G1 Y94.626
G0 Y94.726
G1 Y138.395
G1 Y138.419
G1 X178.297Y138.439
G1 X178.311Y138.456
G1 X178.328
G1 X178.346Y138.473
G1 X178.362
G1 X222.031
G0 X222.131
G1 X265.808
G1 X265.829
G1 X265.848Y138.457
G1 X265.864Y138.442
G1 X265.874Y138.419
G1 Y138.395
G1 Y94.726
G0 Y94.626
G1 Y50.944
G1 Y50.928
G1 Y50.913
G1 X265.851Y50.896
G1 X265.827Y50.882
G1 X265.805
G1 X222.131
G0 X222.031
G1 X178.362
G1 X178.338
G1 X178.313Y50.895
M9
G0 X182.711Y55.254
Layer C16
G1 X182.69F1400
G1 X182.677Y55.274
G1 X182.667Y55.287
G1 X182.656Y55.313
G1 Y55.329
G1 Y94.626
G0 Y94.726
G1 Y134.023
G1 Y134.048
G1 X182.687Y134.088
G1 X182.734Y134.103
G1 X222.031
G0 X222.131
G1 X261.436
G1 X261.468Y134.092
G1 X261.483Y134.08
G1 X261.496Y134.065
G1 Y134.045
G1 X261.508Y134.023
G1 Y94.726
G0 Y94.626
G1 Y55.316
G1 Y55.294
G1 X261.491Y55.28
G1 X261.477Y55.267
G1 X261.46Y55.256
G1 X261.433
G1 X222.131
G0 X222.031
G1 X182.734
G1 X182.711
M9
G0 X187.041Y59.657
Layer C17
G1 Y59.674F1300
G1 X187.026Y59.701
G1 Y94.626
G0 Y94.726
G1 Y129.651
G1 Y129.676
G1 X187.048Y129.704
G1 X187.074Y129.724
G1 X187.106
G1 X222.031
G0 X222.131
G1 X257.056
G1 X257.086
G1 X257.106Y129.71
G1 X257.124Y129.694
G1 Y129.673
G1 X257.136Y129.651
G1 Y94.726
G0 Y94.626
G1 Y59.688
G1 X257.125Y59.661
G1 X257.112Y59.644
G1 X257.094Y59.631
G1 X257.078
G1 X257.062
G1 X222.131
G0 X222.031
G1 X187.106
G1 X187.088
G1 X187.071
G1 X187.053Y59.642
G1 X187.041Y59.657
M9
G0 X191.429Y64.01
Layer C18
G1 X191.417Y64.021F1200
G1 X191.403Y64.046
G1 Y64.073
G1 Y94.626
G0 Y94.726
G1 Y125.279
G1 Y125.3
G1 Y125.319
G1 X191.422Y125.337
G1 X191.449Y125.351
G1 X191.478
G1 X222.031
G0 X222.131
G1 X252.684
G1 X252.705
G1 X252.724
G1 X252.752Y125.322
G1 Y125.301
G1 X252.764Y125.279
G1 Y94.726
G0 Y94.626
G1 Y64.059
G1 X252.753Y64.033
G1 Y64.02
G1 X252.731Y64.008
G1 X252.711
G1 X252.69Y63.993
G1 X222.131
G0 X222.031
G1 X191.478
G1 X191.443
G1 X191.429Y64.01
M9
G0 X195.829Y68.368
Layer C19
G1 X195.81F1100
G1 X195.785Y68.398
G1 X195.771Y68.428
G1 Y68.445
G1 Y94.626
G0 Y94.726
G1 Y120.916
G1 X195.783Y120.952
G1 X195.803Y120.972
G1 X195.828Y120.984
G1 X195.85
G1 X222.031
G0 X222.131
G1 X248.321
G1 X248.357Y120.974
G1 X248.371Y120.96
G1 X248.383Y120.945
G1 Y120.926
G1 Y120.907
G1 Y94.726
G0 Y94.626
G1 Y68.445
G1 Y68.42
G1 X248.373Y68.394
G1 X248.35Y68.374
G1 X248.334
G1 X248.318
G1 X222.131
G0 X222.031
G1 X195.85
G1 X195.829
M9
G0 X146.69Y175.714
Layer C20
G1 X146.663F1000
G1 X81.135
G0 X81.035
G1 X15.493
G1 X15.467
G1 X15.442Y175.741
G1 X15.43Y175.766
G1 Y175.788
G1 Y241.316
G0 Y241.416
G1 Y306.944
G1 Y306.969
G1 X15.441Y306.989
G1 X15.456Y307.005
G1 X15.475Y307.017
G1 X15.491
G1 X15.507
G1 X81.035
G0 X81.135
G1 X146.663
G1 X146.708
G1 X146.731Y306.986
G1 Y306.965
G1 X146.743Y306.944
G1 Y241.416
G0 Y241.316
G1 Y175.788
G1 Y175.763
G1 X146.714Y175.727
G1 X146.69Y175.714
M9
G0 X142.359Y180.121
Layer C21
G1 X142.347Y180.102F900
G1 X142.333
G1 X142.318Y180.085
G1 X142.291
G1 X81.135
G0 X81.035
G1 X19.865
G1 X19.854
G1 X19.83Y180.097
G1 X19.814Y180.113
G1 X19.804Y180.133
G1 Y180.16
G1 Y241.316
G0 Y241.416
G1 Y302.586
G1 Y302.597
G1 Y302.614
G1 X19.823Y302.63
G1 X19.846Y302.645
G1 X19.862
G1 X19.879
G1 X81.035
G0 X81.135
G1 X142.291
G1 X142.324
G1 X142.352Y302.624
G1 X142.364Y302.599
G1 Y302.572
G1 Y241.416
G0 Y241.316
G1 Y180.16
G1 Y180.141
G1 Y180.121
M9
G0 X137.951Y184.46
Layer C22
G1 X137.925F800
G1 X81.135
G0 X81.035
G1 X24.241
G1 X24.216
G1 X24.193Y184.476
G1 X24.182Y184.492
G1 Y184.51
G1 X24.171Y184.532
G1 Y241.316
G0 Y241.416
G1 Y298.2
G1 Y298.219
G1 X24.181Y298.24
G1 X24.199Y298.261
G1 X24.218Y298.273
G1 X24.251
G1 X81.035
G0 X81.135
G1 X137.919
G1 X137.938
G1 X137.965
G1 X137.987Y298.243
G1 Y298.222
G1 X137.999Y298.2
G1 Y241.416
G0 Y241.316
G1 Y184.532
G1 Y184.511
G1 X137.989Y184.492
G1 X137.975Y184.474
G1 X137.951Y184.46
M9
G0 X133.606Y188.851
Layer C23
G1 X133.59Y188.836F700
G1 X133.572
G1 X133.553Y188.824
G1 X81.135
G0 X81.035
G1 X28.609
G1 X28.588
G1 X28.573Y188.841
G1 X28.558Y188.857
G1 X28.547Y188.876
G1 Y188.904
G1 Y241.316
G0 Y241.416
G1 Y293.842
G1 Y293.863
G1 X28.56Y293.878
G1 X28.58Y293.896
G1 X28.603
G1 X28.623Y293.908
G1 X81.035
G0 X81.135
G1 X133.547
G1 X133.587Y293.898
G1 X133.605Y293.88
G1 X133.62Y293.861
G1 Y293.828
G1 Y241.416
G0 Y241.316
G1 Y188.89
G1 Y188.869
G1 X133.606Y188.851
M9
G0 X129.25Y193.25
Layer C24
G1 X129.239Y193.226F600
G1 X129.203Y193.2
G1 X129.176
G1 X81.135
G0 X81.035
G1 X32.995
G1 X32.97
G1 X32.955
G1 X32.937Y193.22
G1 X32.927Y193.233
G1 Y193.254
G1 X32.915Y193.276
G1 Y241.316
G0 Y241.416
G1 Y289.457
G1 Y289.476
G1 X32.928Y289.501
G1 X32.943Y289.518
G1 X32.968Y289.53
G1 X32.995
G1 X81.035
G0 X81.135
G1 X129.189
G1 X129.217
G1 X129.24Y289.504
G1 X129.256Y289.457
G1 Y241.416
G0 Y241.316
G1 Y193.276
G1 Y193.25
M9
G0 X124.804Y197.647
Layer C25
G1 X81.135F500
G0 X81.035
G1 X37.366
G1 Y241.316
G0 Y241.416
G1 Y285.085
G1 X81.035
G0 X81.135
G1 X124.804
G1 Y241.416
G0 Y241.316
G1 Y197.647
M9
G0 X120.506Y201.994
Layer C26
G1 X120.495Y201.97F400
G1 X120.479Y201.955
G1 X120.459
G1 X120.437Y201.939
G1 X81.135
G0 X81.035
G1 X41.725
G1 X41.709
G1 X41.689Y201.956
G1 X41.677Y201.968
G1 X41.664Y201.992
G1 Y202.019
G1 Y241.316
G0 Y241.416
G1 Y280.727
G1 Y280.75
G1 X41.679Y280.766
G1 X41.691Y280.777
G1 X41.706
G1 X41.722Y280.791
G1 X41.738
G1 X81.035
G0 X81.135
G1 X120.432
G1 X120.454
G1 X120.476Y280.779
G1 X120.491Y280.763
G1 X120.505Y280.745
G1 Y280.713
G1 Y241.416
G0 Y241.316
G1 Y202.019
G1 Y201.994
M9
G0 X116.06Y206.391
Layer text
G1 X81.135F300
G0 X81.035
G1 X46.11
G1 Y241.316
G0 Y241.416
G1 Y276.341
G1 X81.035
G0 X81.135
G1 X116.06
G1 Y241.416
G0 Y241.316
G1 Y206.391
M9
G0 X66.258Y319.09
Layer C29
G91
G1 X-1.25F3000S0
G1 X-0.303S1000
G1 X-1.25S0
G1 X-18.004Y-0.1S0
G1 X1.25S0
G1 X1.22S1000
G1 X3.676S0
G1 X1.22S1000
G1 X3.677S0
G1 X1.22S1000
G1 X6.475S0
G1 X1.341S1000
G1 X3.642S0
G1 X1.22S1000
G1 X3.676S0
G1 X1.221S1000
G1 X1.25S0
G1 X0.242Y-0.1S0
G1 X-1.25S0
G1 X-1.702S1000
G1 X-3.195S0
G1 X-1.701S1000
G1 X-3.129S0
G1 X-1.866S1000
G1 X-5.982S0
G1 X-1.702S1000
G1 X-3.195S0
G1 X-1.701S1000
G1 X-3.195S0
G1 X-1.702S1000
G1 X-3.184S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X3.008S0
G1 X2.056S1000
G1 X2.84S0
G1 X2.057S1000
G1 X2.839S0
G1 X2.057S1000
G1 X5.62S0
G1 X2.258S1000
G1 X2.744S0
G1 X2.056S1000
G1 X2.84S0
G1 X2.057S1000
G1 X1.25S0
G1 X0.128Y-0.1S0
G1 X-1.25S0
G1 X-2.316S1000
G1 X-2.581S0
G1 X-2.315S1000
G1 X-2.478S0
G1 X-2.544S1000
G1 X-5.341S0
G1 X-2.315S1000
G1 X-2.581S0
G1 X-2.316S1000
G1 X-2.581S0
G1 X-2.315S1000
G1 X-2.877S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.763S0
G1 X2.54S1000
G1 X2.356S0
G1 X2.541S1000
G1 X2.356S0
G1 X2.54S1000
G1 X5.1S0
G1 X2.807S1000
G1 X2.231S0
G1 X2.54S1000
G1 X2.357S0
G1 X2.54S1000
G1 X1.25S0
G1 X0.103Y-0.1S0
G1 X-1.25S0
G1 X-2.74S1000
G1 X-2.156S0
G1 X-2.74S1000
G1 X-2.033S0
G1 X-3S1000
G1 X-4.906S0
G1 X-2.74S1000
G1 X-2.156S0
G1 X-2.74S1000
G1 X-2.157S0
G1 X-2.739S1000
G1 X-2.667S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.585S0
G1 X1.143S1000
G1 X0.628S0
G1 X1.123S1000
G1 X2.003S0
G1 X1.143S1000
G1 X0.627S0
G1 X1.123S1000
G1 X2.003S0
G1 X1.143S1000
G1 X0.627S0
G1 X1.124S1000
G1 X4.742S0
G1 X1.193S1000
G1 X0.767S0
G1 X1.222S1000
G1 X1.861S0
G1 X1.135S1000
G1 X0.612S0
G1 X1.146S1000
G1 X2.003S0
G1 X1.136S1000
G1 X0.611S0
G1 X1.147S1000
G1 X1.25S0
G1 X0.072Y-0.1S0
G1 X-1.25S0
G1 X-0.995S1000
G1 X-1.055S0
G1 X-0.986S1000
G1 X-1.86S0
G1 X-0.996S1000
G1 X-1.055S0
G1 X-0.986S1000
G1 X-1.699S0
G1 X-1.083S1000
G1 X-1.219S0
G1 X-1.051S1000
G1 X-4.589S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-1.86S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-1.859S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-2.515S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.452S0
G1 X0.916S1000
G1 X1.349S0
G1 X0.899S1000
G1 X1.733S0
G1 X0.915S1000
G1 X1.349S0
G1 X0.899S1000
G1 X1.733S0
G1 X0.916S1000
G1 X1.349S0
G1 X0.899S1000
G1 X4.464S0
G1 X0.966S1000
G1 X1.517S0
G1 X0.993S1000
G1 X1.575S0
G1 X0.909S1000
G1 X1.342S0
G1 X0.912S1000
G1 X1.733S0
G1 X0.91S1000
G1 X1.341S0
G1 X0.913S1000
G1 X1.25S0
G1 X0.054Y-0.1S0
G1 X-1.25S0
G1 X-0.863S1000
G1 X-1.55S0
G1 X-0.854S1000
G1 X-1.629S0
G1 X-0.864S1000
G1 X-1.549S0
G1 X-0.854S1000
G1 X-1.465S0
G1 X-0.936S1000
G1 X-1.733S0
G1 X-0.929S1000
G1 X-4.349S0
G1 X-0.846S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-1.629S0
G1 X-0.846S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-1.629S0
G1 X-0.847S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-2.403S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.354S0
G1 X0.825S1000
G1 X1.726S0
G1 X0.82S1000
G1 X1.525S0
G1 X0.826S1000
G1 X1.725S0
G1 X0.821S1000
G1 X1.525S0
G1 X0.825S1000
G1 X1.726S0
G1 X0.82S1000
G1 X4.24S0
G1 X0.902S1000
G1 X1.9S0
G1 X0.91S1000
G1 X1.355S0
G1 X0.826S1000
G1 X1.712S0
G1 X0.834S1000
G1 X1.525S0
G1 X0.826S1000
G1 X1.712S0
G1 X0.833S1000
G1 X1.25S0
G1 X0.047Y-0.1S0
G1 X-1.25S0
G1 X-0.806S1000
G1 X-1.849S0
G1 X-0.798S1000
G1 X-1.444S0
G1 X-0.805S1000
G1 X-1.849S0
G1 X-0.798S1000
G1 X-1.278S0
G1 X-0.872S1000
G1 X-2.047S0
G1 X-0.874S1000
G1 X-4.155S0
G1 X-0.801S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-1.444S0
G1 X-0.8S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-1.444S0
G1 X-0.801S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-2.319S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.286S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X1.372S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X1.371S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X4.078S0
G1 X0.854S1000
G1 X2.162S0
G1 X0.852S1000
G1 X1.208S0
G1 X0.779S1000
G1 X1.947S0
G1 X0.798S1000
G1 X1.372S0
G1 X0.779S1000
G1 X1.947S0
G1 X0.799S1000
G1 X1.25S0
G1 X0.039Y-0.1S0
G1 X-1.25S0
G1 X-0.792S1000
G1 X-2.026S0
G1 X-0.779S1000
G1 X-1.299S0
G1 X-0.793S1000
G1 X-2.026S0
G1 X-0.778S1000
G1 X-1.138S0
G1 X-0.836S1000
G1 X-2.265S0
G1 X-0.841S1000
G1 X-4.002S0
G1 X-0.786S1000
G1 X-2.044S0
G1 X-0.767S1000
G1 X-1.299S0
G1 X-0.786S1000
G1 X-2.045S0
G1 X-0.766S1000
G1 X-1.3S0
G1 X-0.786S1000
G1 X-2.044S0
G1 X-0.767S1000
G1 X-2.253S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.22S0
G1 X0.767S1000
G1 X2.11S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.766S1000
G1 X2.11S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.767S1000
G1 X2.11S0
G1 X0.787S1000
G1 X3.949S0
G1 X0.821S1000
G1 X2.342S0
G1 X0.831S1000
G1 X1.072S0
G1 X0.778S1000
G1 X2.098S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.779S1000
G1 X2.098S0
G1 X0.787S1000
G1 X1.25S0
G1 X0.025Y-0.1S0
G1 X-1.25S0
G1 X-0.79S1000
G1 X-2.154S0
G1 X-0.778S1000
G1 X-1.175S0
G1 X-0.79S1000
G1 X-2.153S0
G1 X-0.779S1000
G1 X-1.022S0
G1 X-0.816S1000
G1 X-2.411S0
G1 X-0.8S1000
G1 X-3.907S0
G1 X-0.79S1000
G1 X-2.156S0
G1 X-0.776S1000
G1 X-1.174S0
G1 X-0.791S1000
G1 X-2.155S0
G1 X-0.776S1000
G1 X-1.175S0
G1 X-0.79S1000
G1 X-2.156S0
G1 X-0.776S1000
G1 X-2.187S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.164S0
G1 X0.775S1000
G1 X2.202S0
G1 X0.793S1000
G1 X1.126S0
G1 X0.776S1000
G1 X2.201S0
G1 X0.794S1000
G1 X1.126S0
G1 X0.775S1000
G1 X2.202S0
G1 X0.793S1000
G1 X3.865S0
G1 X0.794S1000
G1 X2.458S0
G1 X0.808S1000
G1 X0.983S0
G1 X0.772S1000
G1 X2.205S0
G1 X0.794S1000
G1 X1.125S0
G1 X0.773S1000
G1 X2.204S0
G1 X0.794S1000
G1 X1.25S0
G1 X0.024Y-0.1S0
G1 X-1.25S0
G1 X-0.796S1000
G1 X-2.249S0
G1 X-0.772S1000
G1 X-1.08S0
G1 X-0.795S1000
G1 X-2.25S0
G1 X-0.771S1000
G1 X-0.945S0
G1 X-0.813S1000
G1 X-2.491S0
G1 X-0.525S1000
G1 X-4.088S0
G1 X-0.796S1000
G1 X-2.247S0
G1 X-0.773S1000
G1 X-1.08S0
G1 X-0.796S1000
G1 X-2.247S0
G1 X-0.774S1000
G1 X-1.08S0
G1 X-0.795S1000
G1 X-2.248S0
G1 X-0.773S1000
G1 X-2.142S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.12S0
G1 X0.772S1000
G1 X2.292S0
G1 X0.79S1000
G1 X1.042S0
G1 X0.772S1000
G1 X2.293S0
G1 X0.789S1000
G1 X1.043S0
G1 X0.772S1000
G1 X2.292S0
G1 X0.79S1000
G1 X7.099S0
G1 X0.809S1000
G1 X0.916S0
G1 X0.771S1000
G1 X2.294S0
G1 X0.789S1000
G1 X1.042S0
G1 X0.771S1000
G1 X2.294S0
G1 X0.79S1000
G1 X1.25S0
G1 X0.015Y-0.1S0
G1 X-1.25S0
G1 X-0.784S1000
G1 X-2.338S0
G1 X-0.77S1000
G1 X-1.004S0
G1 X-0.785S1000
G1 X-2.337S0
G1 X-0.77S1000
G1 X-0.898S0
G1 X-0.811S1000
G1 X-3.893S0
G1 X-2.361S1000
G1 X-0.824S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.778S1000
G1 X-1.005S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.779S1000
G1 X-1.005S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.778S1000
G1 X-2.098S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.076S0
G1 X0.784S1000
G1 X2.359S0
G1 X0.786S1000
G1 X0.967S0
G1 X0.785S1000
G1 X2.358S0
G1 X0.786S1000
G1 X0.968S0
G1 X0.784S1000
G1 X2.359S0
G1 X0.786S1000
G1 X0.808S0
G1 X2.361S1000
G1 X3.885S0
G1 X0.815S1000
G1 X0.88S0
G1 X0.775S1000
G1 X2.368S0
G1 X0.786S1000
G1 X0.967S0
G1 X0.775S1000
G1 X2.368S0
G1 X0.787S1000
G1 X1.25S0
G1 X0.015Y-0.1S0
G1 X-1.25S0
G1 X-0.788S1000
G1 X-2.395S0
G1 X-0.777S1000
G1 X-0.936S0
G1 X-0.789S1000
G1 X-2.394S0
G1 X-0.777S1000
G1 X-0.869S0
G1 X-0.827S1000
G1 X-3.869S0
G1 X-2.361S1000
G1 X-0.792S0
G1 X-0.789S1000
G1 X-2.387S0
G1 X-0.785S1000
G1 X-0.936S0
G1 X-0.788S1000
G1 X-2.388S0
G1 X-0.784S1000
G1 X-0.936S0
G1 X-0.789S1000
G1 X-2.387S0
G1 X-0.785S1000
G1 X-2.06S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.049S0
G1 X0.78S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.779S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.78S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.78S0
G1 X2.361S1000
G1 X3.841S0
G1 X0.843S1000
G1 X0.869S0
G1 X0.776S1000
G1 X2.421S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.776S1000
G1 X2.42S0
G1 X0.788S1000
G1 X1.25S0
G1 X0.009Y-0.1S0
G1 X-1.25S0
G1 X-0.783S1000
G1 X-2.447S0
G1 X-0.775S1000
G1 X-0.891S0
G1 X-0.784S1000
G1 X-2.446S0
G1 X-0.775S1000
G1 X-0.877S0
G1 X-0.853S1000
G1 X-3.812S0
G1 X-2.361S1000
G1 X-0.771S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.781S1000
G1 X-0.892S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.782S1000
G1 X-0.892S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.781S1000
G1 X-2.038S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.026S0
G1 X0.785S1000
G1 X2.462S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.785S1000
G1 X2.461S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.785S1000
G1 X2.462S0
G1 X0.779S1000
G1 X0.761S0
G1 X2.361S1000
G1 X3.763S0
G1 X0.88S1000
G1 X0.888S0
G1 X0.779S1000
G1 X2.467S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.78S1000
G1 X2.466S0
G1 X0.78S1000
G1 X1.25S0
G1 X0.009Y-0.1S0
G1 X-1.25S0
G1 X-0.782S1000
G1 X-2.476S0
G1 X-0.788S1000
G1 X-0.85S0
G1 X-0.783S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-0.913S0
G1 X-0.892S1000
G1 X-3.714S0
G1 X-2.361S1000
G1 X-0.752S0
G1 X-0.782S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-0.85S0
G1 X-0.782S1000
G1 X-2.476S0
G1 X-0.789S1000
G1 X-0.85S0
G1 X-0.782S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-2.015S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.007S0
G1 X0.789S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.833S0
G1 X0.788S1000
G1 X2.489S0
G1 X0.786S1000
G1 X0.833S0
G1 X0.789S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.742S0
G1 X2.361S1000
G1 X3.641S0
G1 X0.928S1000
G1 X0.942S0
G1 X0.794S1000
G1 X2.484S0
G1 X0.786S1000
G1 X0.833S0
G1 X0.794S1000
G1 X2.483S0
G1 X0.787S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.246S0
G1 X-0.785S1000
G1 X-2.492S0
G1 X-0.792S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.491S0
G1 X-0.793S1000
G1 X-0.997S0
G1 X-0.948S1000
G1 X-6.664S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.498S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-2.006S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.005S0
G1 X0.786S1000
G1 X2.504S0
G1 X0.783S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.504S0
G1 X0.782S1000
G1 X0.824S0
G1 X0.786S1000
G1 X2.504S0
G1 X0.783S1000
G1 X6.529S0
G1 X1.022S1000
G1 X1.054S0
G1 X0.791S1000
G1 X2.499S0
G1 X0.783S1000
G1 X0.824S0
G1 X0.79S1000
G1 X2.5S0
G1 X0.783S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.247S0
G1 X-0.781S1000
G1 X-2.507S0
G1 X-0.789S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.508S0
G1 X-0.789S1000
G1 X-1.132S0
G1 X-1.087S1000
G1 X-6.382S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.787S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.509S0
this it without tabs
ok
ok
ok
Starting stream
M106 S0
G00 G17 G40 G21 G54
G90
M4
M9
G0 X15.33Y29.596
Layer outward kerf
G1 X15.279Y29.628
G1 X15.265Y29.659
G1 Y29.675
G1 Y160.831
G1 Y160.856
G1 X15.279Y160.878
G1 X15.301Y160.899
G1 X15.322
G1 X15.344Y160.911
G1 X146.5
G1 X146.529
G1 X146.542Y160.899
G1 X146.553
G1 X146.566Y160.876
G1 Y160.858
G1 X146.58Y160.831
G1 Y29.675
G1 Y29.64
G1 X146.555Y29.618
G1 X146.537Y29.605
G1 X146.521
G1 X146.505
G1 X15.33
M9
G0 X19.702Y33.968
Layer InnerLine
G1 X19.676F2900
G1 X19.658Y33.991
G1 X19.64Y34.02
G1 Y34.047
G1 Y156.468
G1 Y156.494
G1 X19.656Y156.513
G1 X19.673Y156.527
G1 X19.694
G1 X19.716Y156.539
G1 X142.128
G1 X142.163
G1 X142.189Y156.511
G1 X142.203Y156.481
G1 Y156.459
G1 Y34.033
G1 Y34.012
G1 X142.187Y33.994
G1 X142.165Y33.977
G1 X142.15
G1 X142.133
G1 X19.702
M9
G0 X24.074Y38.34
Layer C02
G1 X24.02Y38.376
G1 X24.009Y38.402
G1 Y38.419
G1 Y152.101
G1 Y152.127
G1 X24.036Y152.149
G1 X24.05
G1 X24.065Y152.164
G1 X24.087
G1 X137.77
G1 X137.791
G1 X137.805Y152.15
G1 X137.817Y152.139
G1 X137.83Y152.115
G1 Y152.087
G1 Y38.405
G1 Y38.379
G1 X137.807Y38.358
G1 X137.793
G1 X137.778Y38.343
G1 X137.761
G1 X24.074
M9
G0 X28.442Y42.713
Layer InnerCut
G1 X28.419F2700
G1 X28.402Y42.735
G1 X28.384Y42.763
G1 Y42.791
G1 Y147.729
G1 Y147.745
G1 X28.4Y147.769
G1 X28.427Y147.788
G1 X28.443
G1 X28.459
G1 X133.384
G1 X133.414
G1 X133.449Y147.762
G1 Y147.748
G1 X133.464Y147.715
G1 Y42.781
G1 Y42.756
G1 X133.44Y42.733
G1 X133.424Y42.722
G1 X133.411
G1 X133.384Y42.711
G1 X28.459
G1 X28.442
M9
G0 X32.756Y47.135
Layer FlexCut
G1 Y47.163F2600
G1 Y143.352
G1 Y143.368
G1 X32.768Y143.393
G1 X32.784Y143.408
G1 X32.809Y143.42
G1 X32.831
G1 X129.021
G1 X129.07Y143.399
G1 X129.086Y143.373
G1 Y143.344
G1 Y47.149
G1 Y47.128
G1 X129.068Y47.105
G1 X129.055Y47.095
G1 X129.037
G1 X129.018Y47.083
G1 X32.817
G1 X32.802
G1 X32.774Y47.107
G1 X32.756Y47.135
M9
G0 X37.138Y51.487
Layer Raster1
G1 Y51.534
G1 Y138.972
G1 Y138.996
G1 X37.14Y139.021
G1 X37.161Y139.04
G1 X37.181
G1 X37.203Y139.052
G1 X124.64
G1 X124.66
G1 X124.675
G1 X124.693Y139.03
G1 X124.708Y139.014
G1 X124.72Y138.972
G1 Y51.525
G1 Y51.5
G1 X124.698Y51.479
G1 X124.678Y51.464
G1 X124.662
G1 X124.646
G1 X37.189
G1 X37.158
G1 X37.138Y51.487
M9
G0 X41.495Y55.906
Layer Raster2
G1 Y134.614F2400
G1 Y134.63
G1 X41.515Y134.653
G1 X41.53Y134.666
G1 X41.558Y134.678
G1 X41.575
G1 X120.278
G1 X120.313Y134.666
G1 X120.333Y134.647
G1 X120.344Y134.627
G1 Y134.6
G1 Y55.893
G1 Y55.866
G1 X120.32Y55.845
G1 X120.301Y55.833
G1 X120.274
G1 X41.575
G1 X41.55
G1 X41.53
G1 X41.51Y55.859
G1 X41.497Y55.89
G1 Y55.906
M9
G0 X45.932Y60.2
Layer Raster3
G1 X45.917F2300
G1 X45.889Y60.223
G1 X45.876Y60.241
G1 Y60.262
G1 Y60.278
G1 Y130.228
G1 Y130.253
G1 Y130.273
G1 X45.891Y130.286
G1 X45.904
G1 X45.919Y130.303
G1 X45.947
G1 X115.896
G1 X115.916
G1 X115.931
G1 X115.946Y130.291
G1 X115.967Y130.266
G1 Y130.25
G1 Y130.228
G1 Y60.27
G1 Y60.243
G1 X115.956Y60.225
G1 X115.944Y60.214
G1 X115.918Y60.201
G1 X115.896
G1 X45.947
G1 X45.932
M9
G0 X50.286Y64.577
Layer Raster4
G1 X50.251Y64.608
G1 X50.24Y64.634
G1 Y64.65
G1 Y125.856
G1 Y125.881
G1 Y125.896
G1 X50.263Y125.914
G1 X50.276Y125.924
G1 X50.297
G1 X50.319Y125.936
G1 X111.525
G1 X111.56
G1 X111.582Y125.912
G1 X111.598Y125.889
G1 Y125.873
G1 Y125.856
G1 Y64.65
G1 Y64.62
G1 X111.588Y64.601
G1 X111.562Y64.58
G1 X111.547
G1 X111.53
G1 X50.305
G1 X50.286
M9
G0 X54.618Y68.99
Layer C09
G1 Y69F2100
G1 Y69.022
G1 Y121.504
G1 Y121.514
G1 X54.631Y121.538
G1 X54.648Y121.552
G1 X54.663
G1 X54.69Y121.564
G1 X107.153
G1 X107.172
G1 X107.202Y121.547
G1 X107.214Y121.536
G1 X107.228Y121.512
G1 Y121.484
G1 Y69.014
G1 Y68.992
G1 X107.212Y68.969
G1 X107.19Y68.951
G1 X107.175
G1 X107.158
G1 X54.682
G1 X54.656
G1 X54.629Y68.97
G1 X54.618Y68.99
M9
G0 X156.433Y29.061
Layer C10
G1 Y29.082F2000
G1 Y29.098
G1 Y160.264
G1 Y160.299
G1 X156.452Y160.315
G1 X156.476Y160.329
G1 X156.503
G1 X287.667
G1 X287.694
G1 X287.717Y160.31
G1 Y160.297
G1 X287.739Y160.254
G1 Y29.098
G1 Y29.073
G1 X287.725Y29.054
G1 X287.71Y29.037
G1 X287.696
G1 X287.681Y29.021
G1 X287.659
G1 X156.503
G1 X156.473
G1 X156.446Y29.042
G1 X156.433Y29.061
M9
G0 X160.798Y33.448
Layer C11
G1 Y33.47F1900
G1 Y155.882
G1 Y155.907
G1 X160.819Y155.94
G1 X160.833
G1 X160.851Y155.957
G1 X160.875
G1 X283.287
G1 X283.307
G1 X283.327
G1 X283.352Y155.929
G1 Y155.906
G1 X283.367Y155.882
G1 Y33.47
G1 Y33.44
G1 X283.347Y33.417
G1 X283.33Y33.402
G1 X283.312
G1 X283.293Y33.39
G1 X160.867
G1 X160.84
G1 X160.826Y33.407
G1 X160.81Y33.423
G1 X160.798Y33.448
M9
G0 X165.232Y37.764
Layer C12
G1 X165.217F1800
G1 X165.193Y37.782
G1 X165.176Y37.804
G1 Y37.825
G1 Y37.842
G1 Y151.519
G1 Y151.55
G1 X165.191Y151.568
G1 X165.225Y151.587
G1 X165.247
G1 X278.915
G1 X278.955
G1 X278.977Y151.562
G1 X278.99Y151.538
G1 Y151.51
G1 Y37.842
G1 Y37.817
G1 X278.978Y37.792
G1 X278.966Y37.781
G1 X278.953
G1 X278.937Y37.766
G1 X278.921
G1 X165.247
G1 X165.232
M9
G0 X169.589Y42.14
Layer Line Cut
G1 X169.551Y42.171
G1 X169.54Y42.197
G1 Y42.214
G1 Y147.147
G1 Y147.178
G1 X169.576Y147.206
G1 X169.597
G1 X169.619Y147.219
G1 X274.543
G1 X274.576Y147.209
G1 X274.605Y147.19
G1 X274.616Y147.171
G1 Y147.138
G1 Y42.195
G1 Y42.179
G1 X274.601Y42.158
G1 X274.571Y42.139
G1 X274.543
G1 X169.61
G1 X169.589
M9
G0 X173.981Y46.506
Layer C14
G1 X173.933Y46.53
G1 X173.923Y46.543
G1 Y46.564
G1 X173.91Y46.586
G1 Y142.78
G1 X173.921Y142.803
G1 X173.935Y142.824
G1 X173.953Y142.837
G1 X173.99
G1 X270.171
G1 X270.201
G1 X270.239Y142.809
G1 Y142.788
G1 X270.251Y142.767
G1 Y46.586
G1 Y46.571
G1 Y46.556
G1 X270.234Y46.536
G1 X270.22Y46.523
G1 X270.204Y46.513
G1 X270.177
G1 X173.981
M9
G0 X178.313Y50.895
Layer C15
G1 Y50.936
G1 X178.282Y50.958
G1 Y138.395
G1 Y138.419
G1 X178.297Y138.439
G1 X178.311Y138.456
G1 X178.328
G1 X178.346Y138.473
G1 X178.362
G1 X265.808
G1 X265.829
G1 X265.848Y138.457
G1 X265.864Y138.442
G1 X265.874Y138.419
G1 Y138.395
G1 Y50.944
G1 Y50.928
G1 Y50.913
G1 X265.851Y50.896
G1 X265.827Y50.882
G1 X265.805
G1 X178.362
G1 X178.338
G1 X178.313Y50.895
M9
G0 X182.711Y55.254
Layer C16
G1 X182.69F1400
G1 X182.677Y55.274
G1 X182.667Y55.287
G1 X182.656Y55.313
G1 Y55.329
G1 Y134.023
G1 Y134.048
G1 X182.687Y134.088
G1 X182.734Y134.103
G1 X261.436
G1 X261.468Y134.092
G1 X261.483Y134.08
G1 X261.496Y134.065
G1 Y134.045
G1 X261.508Y134.023
G1 Y55.316
G1 Y55.294
G1 X261.491Y55.28
G1 X261.477Y55.267
G1 X261.46Y55.256
G1 X261.433
G1 X182.734
G1 X182.711
M9
G0 X187.041Y59.657
Layer C17
G1 Y59.674F1300
G1 X187.026Y59.701
G1 Y129.651
G1 Y129.676
G1 X187.048Y129.704
G1 X187.074Y129.724
G1 X187.106
G1 X257.056
G1 X257.086
G1 X257.106Y129.71
G1 X257.124Y129.694
G1 Y129.673
G1 X257.136Y129.651
G1 Y59.688
G1 X257.125Y59.661
G1 X257.112Y59.644
G1 X257.094Y59.631
G1 X257.078
G1 X257.062
G1 X187.106
G1 X187.088
G1 X187.071
G1 X187.053Y59.642
G1 X187.041Y59.657
M9
G0 X191.429Y64.01
Layer C18
G1 X191.403Y64.046
G1 Y64.073
G1 Y125.279
G1 Y125.3
G1 Y125.319
G1 X191.422Y125.337
G1 X191.449Y125.351
G1 X191.478
G1 X252.684
G1 X252.705
G1 X252.724
G1 X252.752Y125.322
G1 Y125.301
G1 X252.764Y125.279
G1 Y64.059
G1 X252.753Y64.033
G1 Y64.02
G1 X252.731Y64.008
G1 X252.711
G1 X252.69Y63.993
G1 X191.478
G1 X191.443
G1 X191.429Y64.01
M9
G0 X195.829Y68.368
Layer C19
G1 X195.81F1100
G1 X195.785Y68.398
G1 X195.771Y68.428
G1 Y68.445
G1 Y120.916
G1 X195.783Y120.952
G1 X195.803Y120.972
G1 X195.828Y120.984
G1 X195.85
G1 X248.321
G1 X248.357Y120.974
G1 X248.371Y120.96
G1 X248.383Y120.945
G1 Y120.926
G1 Y120.907
G1 Y68.445
G1 Y68.42
G1 X248.373Y68.394
G1 X248.35Y68.374
G1 X248.334
G1 X248.318
G1 X195.85
G1 X195.829
M9
G0 X146.69Y175.714
Layer C20
G1 X146.663F1000
G1 X15.493
G1 X15.467
G1 X15.442Y175.741
G1 X15.43Y175.766
G1 Y175.788
G1 Y306.944
G1 Y306.969
G1 X15.441Y306.989
G1 X15.456Y307.005
G1 X15.475Y307.017
G1 X15.491
G1 X15.507
G1 X146.663
G1 X146.708
G1 X146.731Y306.986
G1 Y306.965
G1 X146.743Y306.944
G1 Y175.788
G1 Y175.763
G1 X146.714Y175.727
G1 X146.69Y175.714
M9
G0 X142.359Y180.121
Layer C21
G1 X142.333
G1 X142.318Y180.085
G1 X142.291
G1 X19.865
G1 X19.854
G1 X19.83Y180.097
G1 X19.814Y180.113
G1 X19.804Y180.133
G1 Y180.16
G1 Y302.586
G1 Y302.597
G1 Y302.614
G1 X19.823Y302.63
G1 X19.846Y302.645
G1 X19.862
G1 X19.879
G1 X142.291
G1 X142.324
G1 X142.352Y302.624
G1 X142.364Y302.599
G1 Y302.572
G1 Y180.16
G1 Y180.141
G1 Y180.121
M9
G0 X137.951Y184.46
Layer C22
G1 X137.925F800
G1 X24.241
G1 X24.216
G1 X24.193Y184.476
G1 X24.182Y184.492
G1 Y184.51
G1 X24.171Y184.532
G1 Y298.2
G1 Y298.219
G1 X24.181Y298.24
G1 X24.199Y298.261
G1 X24.218Y298.273
G1 X24.251
G1 X137.919
G1 X137.938
G1 X137.965
G1 X137.987Y298.243
G1 Y298.222
G1 X137.999Y298.2
G1 Y184.532
G1 Y184.511
G1 X137.989Y184.492
G1 X137.975Y184.474
G1 X137.951Y184.46
M9
G0 X133.606Y188.851
Layer C23
G1 X133.572
G1 X133.553Y188.824
G1 X28.609
G1 X28.588
G1 X28.573Y188.841
G1 X28.558Y188.857
G1 X28.547Y188.876
G1 Y188.904
G1 Y293.842
G1 Y293.863
G1 X28.56Y293.878
G1 X28.58Y293.896
G1 X28.603
G1 X28.623Y293.908
G1 X133.547
G1 X133.587Y293.898
G1 X133.605Y293.88
G1 X133.62Y293.861
G1 Y293.828
G1 Y188.89
G1 Y188.869
G1 X133.606Y188.851
M9
G0 X129.25Y193.25
Layer C24
G1 X129.203Y193.2
G1 X129.176
G1 X32.995
G1 X32.97
G1 X32.955
G1 X32.937Y193.22
G1 X32.927Y193.233
G1 Y193.254
G1 X32.915Y193.276
G1 Y289.457
G1 Y289.476
G1 X32.928Y289.501
G1 X32.943Y289.518
G1 X32.968Y289.53
G1 X32.995
G1 X129.189
G1 X129.217
G1 X129.24Y289.504
G1 X129.256Y289.457
G1 Y193.276
G1 Y193.25
M9
G0 X124.804Y197.647
Layer C25
G1 X37.366F500
G1 Y285.085
G1 X124.804
G1 Y197.647
M9
G0 X120.506Y201.994
Layer C26
G1 X120.479Y201.955
G1 X120.459
G1 X120.437Y201.939
G1 X41.725
G1 X41.709
G1 X41.689Y201.956
G1 X41.677Y201.968
G1 X41.664Y201.992
G1 Y202.019
G1 Y280.727
G1 Y280.75
G1 X41.679Y280.766
G1 X41.691Y280.777
G1 X41.706
G1 X41.722Y280.791
G1 X41.738
G1 X120.432
G1 X120.454
G1 X120.476Y280.779
G1 X120.491Y280.763
G1 X120.505Y280.745
G1 Y280.713
G1 Y202.019
G1 Y201.994
M9
G0 X116.06Y206.391
Layer text
G1 X46.11F300
G1 Y276.341
G1 X116.06
G1 Y206.391
M9
G0 X66.258Y319.09
Layer C29
G91
G1 X-1.25F3000S0
G1 X-0.303S1000
G1 X-1.25S0
G1 X-18.004Y-0.1S0
G1 X1.25S0
G1 X1.22S1000
G1 X3.676S0
G1 X1.22S1000
G1 X3.677S0
G1 X1.22S1000
G1 X6.475S0
G1 X1.341S1000
G1 X3.642S0
G1 X1.22S1000
G1 X3.676S0
G1 X1.221S1000
G1 X1.25S0
G1 X0.242Y-0.1S0
G1 X-1.25S0
G1 X-1.702S1000
G1 X-3.195S0
G1 X-1.701S1000
G1 X-3.129S0
G1 X-1.866S1000
G1 X-5.982S0
G1 X-1.702S1000
G1 X-3.195S0
G1 X-1.701S1000
G1 X-3.195S0
G1 X-1.702S1000
G1 X-3.184S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X3.008S0
G1 X2.056S1000
G1 X2.84S0
G1 X2.057S1000
G1 X2.839S0
G1 X2.057S1000
G1 X5.62S0
G1 X2.258S1000
G1 X2.744S0
G1 X2.056S1000
G1 X2.84S0
G1 X2.057S1000
G1 X1.25S0
G1 X0.128Y-0.1S0
G1 X-1.25S0
G1 X-2.316S1000
G1 X-2.581S0
G1 X-2.315S1000
G1 X-2.478S0
G1 X-2.544S1000
G1 X-5.341S0
G1 X-2.315S1000
G1 X-2.581S0
G1 X-2.316S1000
G1 X-2.581S0
G1 X-2.315S1000
G1 X-2.877S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.763S0
G1 X2.54S1000
G1 X2.356S0
G1 X2.541S1000
G1 X2.356S0
G1 X2.54S1000
G1 X5.1S0
G1 X2.807S1000
G1 X2.231S0
G1 X2.54S1000
G1 X2.357S0
G1 X2.54S1000
G1 X1.25S0
G1 X0.103Y-0.1S0
G1 X-1.25S0
G1 X-2.74S1000
G1 X-2.156S0
G1 X-2.74S1000
G1 X-2.033S0
G1 X-3S1000
G1 X-4.906S0
G1 X-2.74S1000
G1 X-2.156S0
G1 X-2.74S1000
G1 X-2.157S0
G1 X-2.739S1000
G1 X-2.667S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.585S0
G1 X1.143S1000
G1 X0.628S0
G1 X1.123S1000
G1 X2.003S0
G1 X1.143S1000
G1 X0.627S0
G1 X1.123S1000
G1 X2.003S0
G1 X1.143S1000
G1 X0.627S0
G1 X1.124S1000
G1 X4.742S0
G1 X1.193S1000
G1 X0.767S0
G1 X1.222S1000
G1 X1.861S0
G1 X1.135S1000
G1 X0.612S0
G1 X1.146S1000
G1 X2.003S0
G1 X1.136S1000
G1 X0.611S0
G1 X1.147S1000
G1 X1.25S0
G1 X0.072Y-0.1S0
G1 X-1.25S0
G1 X-0.995S1000
G1 X-1.055S0
G1 X-0.986S1000
G1 X-1.86S0
G1 X-0.996S1000
G1 X-1.055S0
G1 X-0.986S1000
G1 X-1.699S0
G1 X-1.083S1000
G1 X-1.219S0
G1 X-1.051S1000
G1 X-4.589S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-1.86S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-1.859S0
G1 X-0.977S1000
G1 X-1.065S0
G1 X-0.995S1000
G1 X-2.515S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.452S0
G1 X0.916S1000
G1 X1.349S0
G1 X0.899S1000
G1 X1.733S0
G1 X0.915S1000
G1 X1.349S0
G1 X0.899S1000
G1 X1.733S0
G1 X0.916S1000
G1 X1.349S0
G1 X0.899S1000
G1 X4.464S0
G1 X0.966S1000
G1 X1.517S0
G1 X0.993S1000
G1 X1.575S0
G1 X0.909S1000
G1 X1.342S0
G1 X0.912S1000
G1 X1.733S0
G1 X0.91S1000
G1 X1.341S0
G1 X0.913S1000
G1 X1.25S0
G1 X0.054Y-0.1S0
G1 X-1.25S0
G1 X-0.863S1000
G1 X-1.55S0
G1 X-0.854S1000
G1 X-1.629S0
G1 X-0.864S1000
G1 X-1.549S0
G1 X-0.854S1000
G1 X-1.465S0
G1 X-0.936S1000
G1 X-1.733S0
G1 X-0.929S1000
G1 X-4.349S0
G1 X-0.846S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-1.629S0
G1 X-0.846S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-1.629S0
G1 X-0.847S1000
G1 X-1.565S0
G1 X-0.856S1000
G1 X-2.403S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.354S0
G1 X0.825S1000
G1 X1.726S0
G1 X0.82S1000
G1 X1.525S0
G1 X0.826S1000
G1 X1.725S0
G1 X0.821S1000
G1 X1.525S0
G1 X0.825S1000
G1 X1.726S0
G1 X0.82S1000
G1 X4.24S0
G1 X0.902S1000
G1 X1.9S0
G1 X0.91S1000
G1 X1.355S0
G1 X0.826S1000
G1 X1.712S0
G1 X0.834S1000
G1 X1.525S0
G1 X0.826S1000
G1 X1.712S0
G1 X0.833S1000
G1 X1.25S0
G1 X0.047Y-0.1S0
G1 X-1.25S0
G1 X-0.806S1000
G1 X-1.849S0
G1 X-0.798S1000
G1 X-1.444S0
G1 X-0.805S1000
G1 X-1.849S0
G1 X-0.798S1000
G1 X-1.278S0
G1 X-0.872S1000
G1 X-2.047S0
G1 X-0.874S1000
G1 X-4.155S0
G1 X-0.801S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-1.444S0
G1 X-0.8S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-1.444S0
G1 X-0.801S1000
G1 X-1.858S0
G1 X-0.794S1000
G1 X-2.319S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.286S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X1.372S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X1.371S0
G1 X0.771S1000
G1 X1.97S0
G1 X0.784S1000
G1 X4.078S0
G1 X0.854S1000
G1 X2.162S0
G1 X0.852S1000
G1 X1.208S0
G1 X0.779S1000
G1 X1.947S0
G1 X0.798S1000
G1 X1.372S0
G1 X0.779S1000
G1 X1.947S0
G1 X0.799S1000
G1 X1.25S0
G1 X0.039Y-0.1S0
G1 X-1.25S0
G1 X-0.792S1000
G1 X-2.026S0
G1 X-0.779S1000
G1 X-1.299S0
G1 X-0.793S1000
G1 X-2.026S0
G1 X-0.778S1000
G1 X-1.138S0
G1 X-0.836S1000
G1 X-2.265S0
G1 X-0.841S1000
G1 X-4.002S0
G1 X-0.786S1000
G1 X-2.044S0
G1 X-0.767S1000
G1 X-1.299S0
G1 X-0.786S1000
G1 X-2.045S0
G1 X-0.766S1000
G1 X-1.3S0
G1 X-0.786S1000
G1 X-2.044S0
G1 X-0.767S1000
G1 X-2.253S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.22S0
G1 X0.767S1000
G1 X2.11S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.766S1000
G1 X2.11S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.767S1000
G1 X2.11S0
G1 X0.787S1000
G1 X3.949S0
G1 X0.821S1000
G1 X2.342S0
G1 X0.831S1000
G1 X1.072S0
G1 X0.778S1000
G1 X2.098S0
G1 X0.787S1000
G1 X1.233S0
G1 X0.779S1000
G1 X2.098S0
G1 X0.787S1000
G1 X1.25S0
G1 X0.025Y-0.1S0
G1 X-1.25S0
G1 X-0.79S1000
G1 X-2.154S0
G1 X-0.778S1000
G1 X-1.175S0
G1 X-0.79S1000
G1 X-2.153S0
G1 X-0.779S1000
G1 X-1.022S0
G1 X-0.816S1000
G1 X-2.411S0
G1 X-0.8S1000
G1 X-3.907S0
G1 X-0.79S1000
G1 X-2.156S0
G1 X-0.776S1000
G1 X-1.174S0
G1 X-0.791S1000
G1 X-2.155S0
G1 X-0.776S1000
G1 X-1.175S0
G1 X-0.79S1000
G1 X-2.156S0
G1 X-0.776S1000
G1 X-2.187S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.164S0
G1 X0.775S1000
G1 X2.202S0
G1 X0.793S1000
G1 X1.126S0
G1 X0.776S1000
G1 X2.201S0
G1 X0.794S1000
G1 X1.126S0
G1 X0.775S1000
G1 X2.202S0
G1 X0.793S1000
G1 X3.865S0
G1 X0.794S1000
G1 X2.458S0
G1 X0.808S1000
G1 X0.983S0
G1 X0.772S1000
G1 X2.205S0
G1 X0.794S1000
G1 X1.125S0
G1 X0.773S1000
G1 X2.204S0
G1 X0.794S1000
G1 X1.25S0
G1 X0.024Y-0.1S0
G1 X-1.25S0
G1 X-0.796S1000
G1 X-2.249S0
G1 X-0.772S1000
G1 X-1.08S0
G1 X-0.795S1000
G1 X-2.25S0
G1 X-0.771S1000
G1 X-0.945S0
G1 X-0.813S1000
G1 X-2.491S0
G1 X-0.525S1000
G1 X-4.088S0
G1 X-0.796S1000
G1 X-2.247S0
G1 X-0.773S1000
G1 X-1.08S0
G1 X-0.796S1000
G1 X-2.247S0
G1 X-0.774S1000
G1 X-1.08S0
G1 X-0.795S1000
G1 X-2.248S0
G1 X-0.773S1000
G1 X-2.142S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.12S0
G1 X0.772S1000
G1 X2.292S0
G1 X0.79S1000
G1 X1.042S0
G1 X0.772S1000
G1 X2.293S0
G1 X0.789S1000
G1 X1.043S0
G1 X0.772S1000
G1 X2.292S0
G1 X0.79S1000
G1 X7.099S0
G1 X0.809S1000
G1 X0.916S0
G1 X0.771S1000
G1 X2.294S0
G1 X0.789S1000
G1 X1.042S0
G1 X0.771S1000
G1 X2.294S0
G1 X0.79S1000
G1 X1.25S0
G1 X0.015Y-0.1S0
G1 X-1.25S0
G1 X-0.784S1000
G1 X-2.338S0
G1 X-0.77S1000
G1 X-1.004S0
G1 X-0.785S1000
G1 X-2.337S0
G1 X-0.77S1000
G1 X-0.898S0
G1 X-0.811S1000
G1 X-3.893S0
G1 X-2.361S1000
G1 X-0.824S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.778S1000
G1 X-1.005S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.779S1000
G1 X-1.005S0
G1 X-0.784S1000
G1 X-2.329S0
G1 X-0.778S1000
G1 X-2.098S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.076S0
G1 X0.784S1000
G1 X2.359S0
G1 X0.786S1000
G1 X0.967S0
G1 X0.785S1000
G1 X2.358S0
G1 X0.786S1000
G1 X0.968S0
G1 X0.784S1000
G1 X2.359S0
G1 X0.786S1000
G1 X0.808S0
G1 X2.361S1000
G1 X3.885S0
G1 X0.815S1000
G1 X0.88S0
G1 X0.775S1000
G1 X2.368S0
G1 X0.786S1000
G1 X0.967S0
G1 X0.775S1000
G1 X2.368S0
G1 X0.787S1000
G1 X1.25S0
G1 X0.015Y-0.1S0
G1 X-1.25S0
G1 X-0.788S1000
G1 X-2.395S0
G1 X-0.777S1000
G1 X-0.936S0
G1 X-0.789S1000
G1 X-2.394S0
G1 X-0.777S1000
G1 X-0.869S0
G1 X-0.827S1000
G1 X-3.869S0
G1 X-2.361S1000
G1 X-0.792S0
G1 X-0.789S1000
G1 X-2.387S0
G1 X-0.785S1000
G1 X-0.936S0
G1 X-0.788S1000
G1 X-2.388S0
G1 X-0.784S1000
G1 X-0.936S0
G1 X-0.789S1000
G1 X-2.387S0
G1 X-0.785S1000
G1 X-2.06S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.049S0
G1 X0.78S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.779S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.78S1000
G1 X2.417S0
G1 X0.787S1000
G1 X0.78S0
G1 X2.361S1000
G1 X3.841S0
G1 X0.843S1000
G1 X0.869S0
G1 X0.776S1000
G1 X2.421S0
G1 X0.787S1000
G1 X0.913S0
G1 X0.776S1000
G1 X2.42S0
G1 X0.788S1000
G1 X1.25S0
G1 X0.009Y-0.1S0
G1 X-1.25S0
G1 X-0.783S1000
G1 X-2.447S0
G1 X-0.775S1000
G1 X-0.891S0
G1 X-0.784S1000
G1 X-2.446S0
G1 X-0.775S1000
G1 X-0.877S0
G1 X-0.853S1000
G1 X-3.812S0
G1 X-2.361S1000
G1 X-0.771S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.781S1000
G1 X-0.892S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.782S1000
G1 X-0.892S0
G1 X-0.783S1000
G1 X-2.44S0
G1 X-0.781S1000
G1 X-2.038S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.026S0
G1 X0.785S1000
G1 X2.462S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.785S1000
G1 X2.461S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.785S1000
G1 X2.462S0
G1 X0.779S1000
G1 X0.761S0
G1 X2.361S1000
G1 X3.763S0
G1 X0.88S1000
G1 X0.888S0
G1 X0.779S1000
G1 X2.467S0
G1 X0.779S1000
G1 X0.871S0
G1 X0.78S1000
G1 X2.466S0
G1 X0.78S1000
G1 X1.25S0
G1 X0.009Y-0.1S0
G1 X-1.25S0
G1 X-0.782S1000
G1 X-2.476S0
G1 X-0.788S1000
G1 X-0.85S0
G1 X-0.783S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-0.913S0
G1 X-0.892S1000
G1 X-3.714S0
G1 X-2.361S1000
G1 X-0.752S0
G1 X-0.782S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-0.85S0
G1 X-0.782S1000
G1 X-2.476S0
G1 X-0.789S1000
G1 X-0.85S0
G1 X-0.782S1000
G1 X-2.475S0
G1 X-0.789S1000
G1 X-2.015S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.007S0
G1 X0.789S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.833S0
G1 X0.788S1000
G1 X2.489S0
G1 X0.786S1000
G1 X0.833S0
G1 X0.789S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.742S0
G1 X2.361S1000
G1 X3.641S0
G1 X0.928S1000
G1 X0.942S0
G1 X0.794S1000
G1 X2.484S0
G1 X0.786S1000
G1 X0.833S0
G1 X0.794S1000
G1 X2.483S0
G1 X0.787S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.246S0
G1 X-0.785S1000
G1 X-2.492S0
G1 X-0.792S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.491S0
G1 X-0.793S1000
G1 X-0.997S0
G1 X-0.948S1000
G1 X-6.664S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.498S0
G1 X-0.785S1000
G1 X-0.828S0
G1 X-0.785S1000
G1 X-2.499S0
G1 X-0.785S1000
G1 X-2.006S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.005S0
G1 X0.786S1000
G1 X2.504S0
G1 X0.783S1000
G1 X0.823S0
G1 X0.787S1000
G1 X2.504S0
G1 X0.782S1000
G1 X0.824S0
G1 X0.786S1000
G1 X2.504S0
G1 X0.783S1000
G1 X6.529S0
G1 X1.022S1000
G1 X1.054S0
G1 X0.791S1000
G1 X2.499S0
G1 X0.783S1000
G1 X0.824S0
G1 X0.79S1000
G1 X2.5S0
G1 X0.783S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.247S0
G1 X-0.781S1000
G1 X-2.507S0
G1 X-0.789S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.508S0
G1 X-0.789S1000
G1 X-1.132S0
G1 X-1.087S1000
G1 X-6.382S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.787S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.788S1000
G1 X-0.819S0
G1 X-0.781S1000
G1 X-2.509S0
G1 X-0.787S1000
G1 X-2.004S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.003S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X0.814S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.509S0
G1 X0.784S1000
G1 X5.222S0
G1 X0.095S1000
G1 X0.806S0
G1 X1.254S1000
G1 X1.219S0
G1 X0.788S1000
G1 X2.51S0
G1 X0.784S1000
G1 X0.815S0
G1 X0.787S1000
G1 X2.511S0
G1 X0.784S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.248S0
G1 X-0.789S1000
G1 X-2.511S0
G1 X-0.785S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.511S0
G1 X-0.786S1000
G1 X-1.325S0
G1 X-2.036S1000
G1 X-5.232S0
G1 X-0.789S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-0.812S0
G1 X-0.788S1000
G1 X-2.507S0
G1 X-0.79S1000
G1 X-0.811S0
G1 X-0.789S1000
G1 X-2.506S0
G1 X-0.79S1000
G1 X-2.002S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.003S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X0.815S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X0.816S0
G1 X0.789S1000
G1 X2.504S0
G1 X0.788S1000
G1 X5.248S0
G1 X1.882S1000
G1 X1.467S0
G1 X0.782S1000
G1 X2.511S0
G1 X0.788S1000
G1 X0.816S0
G1 X0.782S1000
G1 X2.51S0
G1 X0.789S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.253S0
G1 X-0.788S1000
G1 X-2.508S0
G1 X-0.781S1000
G1 X-0.819S0
G1 X-0.789S1000
G1 X-2.508S0
G1 X-0.781S1000
G1 X-1.653S0
G1 X-1.684S1000
G1 X-5.264S0
G1 X-0.788S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-0.819S0
G1 X-0.789S1000
G1 X-2.5S0
G1 X-0.789S1000
G1 X-0.819S0
G1 X-0.788S1000
G1 X-2.501S0
G1 X-0.788S1000
G1 X-2.004S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.005S0
G1 X0.787S1000
G1 X2.498S0
G1 X0.788S1000
G1 X0.823S0
G1 X0.788S1000
G1 X2.498S0
G1 X0.788S1000
G1 X0.822S0
G1 X0.788S1000
G1 X2.498S0
G1 X0.788S1000
G1 X5.279S0
G1 X1.372S1000
G1 X1.954S0
G1 X0.786S1000
G1 X2.5S0
G1 X0.788S1000
G1 X0.822S0
G1 X0.786S1000
G1 X2.5S0
G1 X0.788S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.252S0
G1 X-0.789S1000
G1 X-2.491S0
G1 X-0.791S1000
G1 X-0.826S0
G1 X-0.788S1000
G1 X-2.491S0
G1 X-0.791S1000
G1 X-1.786S0
G1 X-1.528S1000
G1 X-5.294S0
G1 X-0.789S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.826S0
G1 X-0.788S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-0.826S0
G1 X-0.789S1000
G1 X-2.495S0
G1 X-0.787S1000
G1 X-2.005S0
G1 X-0.768S1000
G1 X-1.25S0
G1 Y-0.1S0
G1 X1.25S0
G1 X0.768S1000
G1 X2.01S0
G1 X0.787S1000
G1 X2.488S0
G1 X0.786S1000
G1 X0.836S0
G1 X0.786S1000
G1 X2.488S0
G1 X0.787S1000
G1 X0.835S0
G1 X0.787S1000
G1 X2.488S0
G1 X0.786S1000
G1 X5.312S0
G1 X1.656S1000
G1 X1.65S0
G1 X0.792S1000
G1 X2.482S0
G1 X0.787S1000
G1 X0.835S0
G1 X0.792S1000
G1 X2.483S0
G1 X0.786S1000
G1 X1.25S0
G1 Y-0.1S0
G1 X-1.255S0
G1 X-0.784S1000
G1 X-2.474S0
G1 X-0.789S1000
G1 X-0.849S0
G1 X-0.785S1000
G1 X-2.473S0
G1 X-0.79S1000
G1 X-1.538S0
G1 X-1.224S1000
G1 X-5.869S0
JohnJohn
(John Johnson)
March 9, 2022, 6:04pm
19
From the sheer volume of g-code I can see that you are doing many things at many different speeds.
If you can draw a square (Known size - no tabs - known speed setting - and time the edge with a stopwatch) and engrave it at low power and capture the g-code I can try to determine if it is a speed setting in the GRBL controller or a command from LightBurn that is creating problems.
I can not disentangle this problem with the g-code above.
ok here is a single square 60x60mm speed 1200 power output 50% no tabs
�ok:512
ok:IDLE
ok:512
ok:IDLE
ok:512
ok:IDLE
ok
Starting stream
M106 S0
G00 G17 G40 G21 G54
G90
M4
M9
G0 X35.908Y48.827
Layer outward kerf
G1 X35.893S500F1200
G1 X35.87Y48.858
G1 Y48.879
G1 X35.858Y48.901
G1 Y108.92
G1 Y108.936
G1 X35.882Y108.958
G1 X35.896
G1 X35.916Y108.978
G1 X35.938
G1 X95.952
G1 X95.983Y108.967
G1 X95.999Y108.952
G1 X96.011Y108.933
G1 Y108.901
G1 Y48.887
G1 Y48.861
G1 X95.994Y48.843
G1 X95.976Y48.83
G1 X95.96
G1 X95.944
G1 X35.938
G1 X35.908
M9
G1 S0
M5
G90
G0 X100 Y100
M2
Stream completed in 0:00
[MSG:Pgm End]
