2.0 UI problem.. (added to meet the 15 c min requirement)
I know you have a slider for toolbar graphics but you have also changed the switch icons in the layer section, they are over sized and make it look like its from the 90’s also stops the screen resizing correctly for smaller screens.
Anther problem the layer pop up window for layer settings cant be used, the ok button is off the bottom of the screen and the pop up cant be resized, passes has vanished from the quick layer setting so now to change passes i have to use tab and enter and hope i found the ok button with tab… can we get a refund and roll back.. ill get by without any new functionality, would rather have a usable interface
Hello
This issue has been reported by some users with a combination of edge case Windows Scaling and LightBurn High DPI Settings.
Please follow this link for some steps to address the issue.
I am experiencing the same issues. My Windows 10 laptop computer is a small 12" screen and the Cut/Layers window is pretty much unusable. If you try to resize the window, it drops into the status bar and disappears. At that point, the entire program is not useable because you have to click the “Esc” button to close the Cut/Layers window.
I tried the same on a separate Windows 11 laptop with a 15" screen and it works just fine.
Until I can afford another Windows 11 laptop with a 15" screen for my laser, I’ll have to revert back to the earlier version of Lightburn. In the meantime, I hope Lightburn fixes this issue quickly for those of us who cannot buy a new W11 computer right away.
