soorya_sh
(Soorya S)
February 6, 2022, 2:56pm
#1
is there any way i can increase the number of layers in lb more than the currently existing layers
bernd.dk
(Bernd )
February 6, 2022, 4:02pm
#2
No, this is not possible for us. May I ask what you want to use the extra layers for?
The number of layers is a hardware limit in the Ruida controller. If you’re wanting to make a material test grid, which seems to be the only reason anyone ever needs more than 30, you can use the power scale feature to get a range of power outputs in a single layer.
soorya_sh
(Soorya S)
February 7, 2022, 6:15am
#4
I use a KT332N controller…please do let me know where to find the power scale feature
Rick
(Technical Evangelist)
February 7, 2022, 10:06pm
#6
A few links to help get you started using Power Scale.
Here is a test file created using the ‘Array’ and ‘Power Scale’ features. (you must adjust the settings in this file for your setup and needs)
Setup grid array with all rows at 80% Max pwr 0% Min pwr. Set each row at different speed starting at 400mm/s down to 100mm/s from top to bottom of scale.
Viewing left to right, each column uses ‘Power Scale’ to adjust from 10% to 100% (of 80%).
PowerScale Test_01_Rico.lbrn (23.7 KB)
[image]
Here is another in a series of useful Tips, Tricks and How-to videos. Power Scaling - what it is and why you want to use it. Thanks @CarlFisher
note: You may need to turn on the ‘Shape Properties’ window to expose settings (‘Window’>-‘Shape Properties’)
Here is an external link to a member generated tool to help build testing files using the Power Scale feature.
Auto-generate test files for LightBurn. LightBurn Test Generators - Lightburn PowerScale Generators - O2 Creative
soorya_sh
(Soorya S)
February 8, 2022, 7:11am
#7
thank u …I’ll look into it
