Hello everybody,
after a long time I now have a new computer in my workshop.
Now I wanted to reinstall Lightburn on it and take the settings and license from the old computer.
Does it work? If so, what do I have to consider or do?
Old computer was Win 7, newer is Win 10.
Thanks you two it worked great.
However, I cannot open saved projects on the new computer.
I go to load project and then nothing happens. (However, only for projects where, for example, only writing or other characters were in it)
Projects with pictures work without problems.
What have I done wrong now?
the strange thing is, on the old PC under Win 7, all files could be opened and saved without problems and so on.
I am attaching another non-working file (on a new PC, Win 10).
Same, all zeros. What version of LightBurn did you use to create these files? Do you still have access to the system you used to generate these files? Do they still open there?
No, unfortunately I no longer have. Since I have already transferred the license. And now Lightburn no longer opens due to the lack of a license. It was the 9/9 version
Send the trial ID from the old system and I’ll extend it. There is quite possibly something going wrong with copying these files from the old system to the new one.
Here are two pictures of the files I sent you.
They work without problems on the old computer.
Is there a trick to transfer the files safely somehow?
The same Lghtburn 9.0.9 versions are on both PCs.
They’re just files, so there’s nothing exciting about them. You should be able to just copy them like anything else. How are you getting them to the new machine?
They’re text files. The OS shouldn’t matter. The files you posted were nothing but zeros - that’s not normal. You should be able to open an lbrn file in NotePad or any text editor and see readable content.
