How to access the license portal to manage your own activations
The license system used by LightBurn has a web portal that users can access to view the computers on their license, and do some basic tasks like view the computers activated on your license, deactivate unused computers, or process an Offline Activation .
If you purchased your key from LightBurn directly, you will have access to this portal. If you purchased from a 3rd party vendor, we will need to assign your license key to your email address for you to gain access. Contact us at support@lightburnsoftware.com with your full name and license key to have us do so.
Accessing the License Portal
The first time you use the portal you will need to enter the email address assigned to your key and request a password reset.
Follow these instructions to access the License Portal:
  1. Go to https://lightburn.customer.cryptlex.com/.
  2. Click Forgot Password.
  3. Enter the email address where you received your license key, and click Send Reset Link.
  4. You will receive an email from Cryptlex with a password reset link.
  5. Follow the link, choose your new password, then log in.
If you do not see an email from Cryptlex, check your Promotions or Spam folders — the password reset email sometimes ends up there. If you still cannot find it, your email provider might be blocking the email from ever reaching you. Contact us at support@lightburnsoftware.com to have us reassign your key to an address under a different provider. Gmail accounts work well.
Removing an Old Computer From Your Key
If you still have access to the computer you wish to remove from your license:
  1. Open LightBurn on that computer and go to HelpLicense Management.
  2. Click Deactivate License.
If you no longer have access to the computer you wish to remove:
  1. Log in to the License Portal. On the main screen you will see any licenses associated with your email address.
  2. Click on Activations in the left sidebar to view a list of computers assigned to your license key, when they were last used (Last Synced At ), and when they were first activated (Creation Date ).
  3. Click the three dot icon to the right of any computer in the list, to show the option to Delete that computer, removing the license from the computer, and freeing up the license seat for use on another machine.
Processing an Offline Activation
Follow the steps below to activate LightBurn on a computer without access to the internet.
  1. Enter your license key in the License Management window.
  2. Click Request Offline Activation.
  3. You’ll be asked to save a file with an .ofr extension that contains the machine fingerprint as an offline request. Save and copy that file to a USB flash drive and bring it to a machine with a network connection.
  4. Log in to the License Portal on the machine with a network connection.
    a) While viewing your license in the portal, click Activations.
    b) Click Create Offline.
    c) Paste your key into the License Key field.
    d) Click in the Offline Request field to open your system’s file browser, navigate to the location the .ofr file is saved, and select it.
    e) Click Activate.
  5. You’ll see Task Successful if you entered everything properly. Click Download to download the .dat response file.
  6. Transfer the .dat file back to the offline computer by USB flash drive.
  7. On the offline computer, in the License Management window in LightBurn, click Process Offline Activation.
  8. Navigate to the location the .dat response file is saved and select it, completing the Offline Activation process.
Warning
If you see an Invalid license id message instead, you’ll need to repeat the process. Take care to enter your exact license — including hyphens — into LightBurn and the field in the Offline Activation window. Copying and pasting the key directly from your original order email is the best way to ensure accuracy.
If you’re not comfortable performing all of the above steps yourself, email us at support@lightburnsoftware.com, with the .ofr file and license key, and we will process the file and return the .dat response file for you to use to complete the activation.
IMPORTANT
It is not possible to complete this process for a Trial ID. LightBurn must connect to the internet once to activate a trial, after which you are free to take your computer back offline.
Activation limit reached
Offline Activation Procedure
Serial problem - activation limit is reached
FAQ license - logged in and saw no licenses
Install on new computer
Reload LB & reinstate the license on this NEW PC
When your old computer dies, can you trash the license it used?
How do I move my license to a new computer?
Activation license key
Licence Activation?
Time adjustment deactivates licence
3rd license, please
How to remove an old no longer owned laptop off my license?
License Transfer from one laptop to a new one
Downloaded lightburn
New computer but want to use lightburn on both, cant access license portal
Computer had to be rebooted and I lost my software
Reset Key computer died
Install limit reached
Licence key after 12.03 download
Changing home position
How do I move licence key onto new laptop without old laptop?
Lightburn crashing all of a sudden
Silent Installation and Licensing
How to switch license
I paid for Lightburn Pro but it won't update and theres no way to contact support so WTF!
Supprimer une licence
How to get another License
After installation on a new PC, take over the Lightburn settings and license
Query re license key
How to deactive licences on Broken pc?
Lightburn Software Re-install?
How to de-authorize a computer I no longer have access to?
How do i transfer my licence to my offline pc
Cannot use my Lightburn software with new NOVA51?
Lightburn tools are not calibrating with ortur machine
2nd computer possible?
Microsoft updated - Lightburn activation key was apparently lost, and says I've reached activation limit HELP
Email from license
License Key Old Computer Erased
Need license help
Pc rotto, chiave software non accettata
License help needed to reassign
Code no working trial extension
My computer poo'd itself
DSP licence headache
Upgrade to dsp licentie
software lightburn
