this is the error I’m getting after installing 0.9.21. Any sugestions?
Stream completed in 0:00
Starting stream
Layer Mandala
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
Alarm 2 is the machine telling you it hit a hard limit or tried to go out of bounds. Was this ‘Job Origin’ set to ‘Absolute Coords’? It should be and this should help with understanding the Start From options, when to use each, and why. Coordinates & Origin - LightBurn Software Documentation
Absolute Coordinates is the simplest - The page grid you see in the main editing window represents your machine’s work area. Anything you place in that area will be cut in the corresponding place on your machine. Users with small lasers like the K40 will likely find this the simplest and most intuitive option.
I had this happen when I installed 0.9.21 trial. Turned out my X-axis size in lightburn got bumped up to 500mm instead of 400mm somehow. Reset it to 400, moved my project back in the work area and problem solved.
It may not be your problem, but it is easy to check under device settings.
