Automatic Air-Assist on Ortur LM3
Hi,
the Ortur LM3 has an IO-port … described here … Ortur LM3 I/O Port
I found that Lightburn uses M8 and M9 to control Air Assist …
Is there a possibility to change this to eg. M12,M13 to be used on the original Ortur controller ?
Thanks.
The only possible option you have is to use pre and post commands
Edit → device settings → Gcode tab
As far as i know is not possible to change M8/M9
remember though, M12 M13 control Fan M14/M15 the LED none directs the air pump so you will need a relay of sorts
Since I have to regulate the amount of air on the air-assist anyway, this would be a good compromise.
So for each job I turn on the air via a relay and if I want to work without air, I set it to zero.
Thanks for the inspiration :slight_smile:
