Hello together!
I am new here and need your help please
I would like to buy my first CO2 Laser and can’t choose between a 50W and a 60W.
Here the 60W for Example:
and here the 50W:
I would actually prefer the 60W because of the larger work surface, since it also has a network connection and the stronger tube!
On the other hand, the 60W only has a manual and no electrically adjustable bed, but the 50W does.
I would not care about the manually adjustable bed, but I saw earlier that an Ebay link to the 60W shows an Airassist hose on the nozzle, but I couldn’t find an air pump in the accessories.
Of course I can also buy the pump, which would not be a problem, but I could not find an air connection or a switch for the Air Assist on the side of the 60W like the 50W laser has.
can someone tell me whether the 60W has airassist or not and how it works there without air connection and switch.
Relationship whites do you generally have any advice or tip for which I should now choose?
The larger work surface, the stronger tube and the network connection would honestly be more than just appealing to me. It’s only stupid without Air Assist.
I hope everyone can understand my Bad English, because i am a German Userwith terrible English Skills…
Kind Regards
They are MUCH bigger than the working size/area might make you think. Especially if you are going through a door.
