Hi, I have made the grid with the array tool in LB, How do I get it to burn to my base board? Thank you
Run the job. Is there an issue?
yes I try start job and nothing happens.
I can burn anything else but the grid.
Thanks. Maybe I needed to be a bit clearer. We do not charge by the word, so feel free to use more. It helps us. ![]()
What else can you tell us? Do you see any message displayed in the console when you try to run this job? Do you get any messaging at all when trying to run this job? We canāt see what you do so your words are all we have to go on.
Iām sorry I donāt know all the fancy words or meanings but here is what I have⦠Dell laptop with windows 10, OLM2 20w, LB 9.20 only message is ok, and OLF137 is there to. I donāt know how to screen shot so please bear with me. The laser moved from home about 3 inches and did nothing. I tried changing from absolute cords to current position and still nothing.
Waiting for connectionā¦
ok
ok
[AUTHOR: RenShen]
[MODEL: Ortur Laser Master 2]
[OLF: 137]
[DATE:01:15:16 - Apr 20 2020]
[VER:1.1f.20170801:]
[OPT:VZD,35,254]
Target buffer size found
ok
Homing
ok
Project loaded in 4 milliseconds
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the āDevicesā button to reset the connection)
On or near line 3:
Job halted
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [ā$ā for help]
[MSG:ā$Hā|ā$Xā to unlock]
[MSG:Caution: Unlocked]
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
Layer C00
Layer C00
Layer C00
ALARM:2
On or near line 4:
Job halted
ok
OLF 137.
ok
No no, this is completely fine. It is not the āfancyā wording I am looking for. Just more wording, fancy or not. ![]()
Then followed with much more detail. This is my reference. Thank you for your follow up. We are on track now.
For Windows: Keyboard shortcut for print screen - Microsoft Support
For Macs: Take a screenshot - Apple Support
Alarms are not a good sign and need to be addressed. This means, āG-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the āDevicesā button to reset the connection)ā.
There is information here already, so I will not retype. Look at this: Search results for 'Ortur Alarm:2 @OrturTech order:latest' - LightBurn Software Forum
Are you getting the same alarm after making the āresized imageā adjustment? What is the result now? What do you see in the Console? What are the settings for the black layer? Show that tab, then double-click that layer to expose the āCut Settings Editorā window and show us that screen as well.
Iām sorry this is all new to me, Iām learning as I go
I understand, we have all started our journeys at some point. It is fine. I would like to offer you a suggestion. You are trying to do something that requires a bit of knowledge, not extreme by any means, but not a beginning or novice type project. We would like to see you have success as you begin your journey, so we wrote the following to help:
https://lightburnsoftware.github.io/NewDocs/BeginnerWalkthrough.html
Start there and continue to the next page through the completion of the simple project section. This will help with getting the system set up properly and provide a clear overview of the LightBurn basics.
If you are willing, let us know how you get on, and we can go from there.
@OrturTech, I have seen a few Ortur users wanting to burn this type of grid into the waste board for alignment and such. This would be a great learning project for your customers.
Is this something you folks could provide?
Is funny you mention it because grids are important on software like lasergrbl
Most users use them but end up after learning lightburn using current position the most and ignoring the grids
In our facebook group theres grid files in all shapes and sizes. need to investigate the best ones but can provide for sure
Nice. Thank you. And I totally understand. All about education and sharing the different ways to accomplish the goal.
