I would like to ask if its possible to see the camera feed / overlay via network, since I am planning to buy a pro laser cutter 60w-100w with network capability.
The laser will of course be in a different location where its easy to exhaust the fumes out while the work is done in different offices.
If you are asking whether you can see the camera/overlay in LightBurn from a computer connected to the laser via Ethernet, then you have to have an IP camera, and I am not sure this is supported. The camera interface is USB, as all the cameras for use with the software are USB. So, if this is what you are asking, I would say no.
This is a feature that they may or may not consider, so ask them and submit a feature request.
The USB camera is supported, but not at long distance from the computer due to limitations of USB. I might be missing he mark, so look for others reply also.
Charlie
We do not currently provide IP camera support directly, although we do have a few members who have some successful experience getting an IP camera feed working.
Just came across this thread and thought I’d try it out. I happened to have an Axis IP camera pointing at my 3D printers. I used the Axis Streaming Assistant software and it works as expected.
No, this approach is changing how the system “see” the camera. LightBurn is looking for a USB camera, these IP camera solutions provide the linkage and present the camera in the manner we currently require.
