Cutting and framing circle issue (sculpfun S9 )
Hi all, I have a Sculpfun S9 and I am running into an issue that happens when I want to cut or frame a curved line, happens with the circle framing button, and also circles and curved lines cutting in general, when actioned for cutting a circle, the laser does a lot of erratic movements and not making the circle shape at all but a lot of random short movement in a circular way, which is not the case of straight line (squares) at all. Am I missing something in the setting le ? or am I doing something wrong ?
Sorry about my question, i am still discovering the machine and the settings for both cutting and engraving.
Thank you.
If it looks like this:
Or like this:
Then you should download & install a legit copy from the Official Site, plus run a malware check on your PC to ensure you didn’t install anything unexpected.
If it’s not that problem, pictures will let us see what you see.
Thank you.
Seems to be a double post. But as mentioned in the other one, you are most likely using a pirated version of LB. Make sure you bought a valid license at the official homepage only.
I agree. Merged. Thank you.
I checked the License system and a Valid key has been assigned to this user’s email address. Thank you @Lixa for your support. :slight_smile:
Occasionally, defective software re-routes communication with the License server. If you are still experiencing this erratic behavior, the following may help.
