Engraving Ceramic Tile
Hi everyone ! I was trying to do engraving on Ceramic Tiles using Northern method. Tile is sprayed with 3 thin layers of Matt White, and setting on LightBurn software are :
Negative Image :  Off
Invert :  Off
Speed 1800 mm/min,  Laser Power 90%.
The end result was engraving may look OK but after cleaning the tile with AceTone chemical the picture fade and is not 100%. Neje A40640 is high power and should do the job, but result is not 100%. What have I done wrong.
Northern method, is preferred, I will also try to do engraving using Darkly method.
Appreciate your advice please. Thank you.
There are different methods for the NT work.
Generally what happens is there isn’t enough ā€˜heat’ heat generated for the TiO2 to melt/bond to the tile.
I do this, but I buy the powdered TiO2, mix with water and air brush on the tile. I’ve also used LBT100, which is a spray coating that is very similar for co2 lasers.
I’ve found that the proper thickness of the coating is critical along with speed/power to make it useful.
30mm/s seems rather fast to me… might try slowing down a bit.
Hang around, there is some excellent work here done with that method… Might wish to look in the ā€˜Finished Creations’ for some examples…
Good luck
John, check this thread out.
Also here.
