I can’t get my OLM3 to home. I get the error:8 Grbl $ command cannot be used unless Grbl is idle. I have tried resetting, a different USB cable It has happened before but it reset itself. I am looking for some suggestions to get it moving again
Thank you for pointing me in the right direction. I thought it was a power issue so I swapped out the USB cable and the power supply and the unit returned to a working unit again. WE are back Lasering again.
