Frame function not working
Frame function has stopped working. clicking on Frame now sends the laser to the far back and far right. Don’t know if this will help!
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 185]
[OLH: OLM_ESP_PRO_V1.2]
[OLM: GENERAL]
[DATE:22:44:33 - Oct 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,4096,3]
Target buffer size found
ok
Homing
ok
Project loaded in 2 milliseconds
<Idle|MPos:0.000,0.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:4661,4636|VA:23771,0|WCO:100.000,190.000,0.000|Ov:100,100,100|A:S|H:1,7>
ok
[GC:G0 G54 G92 G17 G20 G90 G94 G49 G98 G50 M5 M9 T0 F5993 S0.]
<Idle|MPos:0.000,0.000,0.000|Bf:35,4095|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:4661,4637|VA:23782,0>
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 185.
OLH:OLM_ESP_PRO_V1.2.
OLM: GENERAL.
[MSG: Flame detector Inactive. Luminosity too high]
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,4096|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:4597,4588|VA:23782,0|Ov:100,100,100|A:S>
ok
[GC:G0 G54 G92 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.]
Starting stream
ALARM:2
On or near line 5:
Stream completed in 0:02
ok
OLF:OLF 185.
OLM: GENERAL.
ok
It appears that you have an Workplace Coordinate Offset.
If this is unintentional, open the Console window in LightBurn and type the following:
*RST=#
That should show the before and after and clear the offset.
Feel free to share that in a reply. I’d like to make sure it’s solved.
It seems to happen to Ortur Laser Master 2 Pro S2 less frequently after the Firmware update to OLF187. The firmware update is Highly Recommended:
JohnJohn,
Thanks for the reply! I was able to fix it myself. Short version is that I had used LaserGRBL prior to the problem and had inadvertently changed settings - I went back into LaserGRBL and reset everything there and it fixed the problem in Lightburn. I’m sure your solution would have worked also! Thanks again!
Out of curiosity, as I’ve seen this issue a lot, what in LaserGRBL is being changed to affect the offset? I’ve experimented with this and have not been able to reproduce the issue.
