I wanted to see if anyone out there has had good experience cutting finger joints using a web app like https://www.festi.info/boxes.py/? No matter how many YouTube tutorials I watch, I keep cutting out boxes and no matter the burn correction I use, I cannot find a tight fit.
I watched a few videos and started at a .06 correction, but no matter what I do, none of the sides fit. I am testing using BurnTest - Boxes here creates a few sides to test, no luck.
Anyone else use a different burn correction than .06?
I use boxes.py as well and always set the burn correction to 0… no correction. Then, in Lightburn, I use a kerf offset of 0.08mm – about 1/2 of 0.167mm (measured, as Jack suggested) – to get nice fitting fingers joints.
Great info, looks like I need to do some kerf testing.
Great thoughts! @jkwilborn Yes, looks like I do mean kerf. I was just using the language from the site, but you are correct. @dkj4linux great idea! I like that better, I am never a fan of using data and not knowing where it came from.
I was reading about using a circle inside a box, and messing with kerf there to test. I think ill try that.
Making and reading that Vernier was fun! First one I made had 2 squares go into LaLa Land. Then I had fun with placing them. Then came them popping up when I tried to adjust the slide. I finally used part of the first one to hold them down while I moved the slide. Final result in 2.8mm Baltic ply, 1.3/20 = 0.065 kerf. Not bad in my opinion for the Sculpfun 10w laser.
