Bit of a clumsy title but here goes.
Assuming I run one of those grayscale image files of eyeballs available on the web and find for that my ideal power setting is say 65%.
Now, I come to run a piece that has many shades of grey but no full black areas.
If I run the piece with a max power of 65%, as per the eyeball test will it overburn?
Or does Lightburn assign your maximum power to #000000 (hex for colour black) and scale the power accordingly based upon what your image translates as?
Make sense?
Your question has a few layers of nuance. But the simple answer is no, LB doesnāt take the floor and ceiling darkness values of that particular image and scale the power levels proportionately across those values according to 65% power. Itās kind of the reverse.
Yes butā¦
⦠then donāt understand this part. Not sure I understand what you mean by translates as.
Hereās a simple model of how I understand this works. Iāll preface this by saying that this applies for grayscale images on diode lasers.
- 65% max power sets the upper bound of power used.
- There is also a min power that sets the lower bound of power used.
- Within the upper and lower bounds defined by the 2 previous figures is contained another full scale as dictated by grayscale intensity. So a pure white would translate to the min power value. And pure black would translate to 65% power.
- I donāt know if itās a purely linear scaling of grayscale through that range but I suspect it is. so 50% grayscale would be half-way in power between upper and lower bounds.
As stated earlier this only applies to grayscale. Any dithered image doesnāt use variable power assignments in this way and I believe only diode lasers are supported for this.
you pretty much stated what I was trying to get across.
so if max power is set at 65%, min at 0% and I engrave an image in grayscale with a range of tones but none pure white or black then Lightburn will tailor the output power to suit.
yes?
Some of your wording is making me feel like thereās still a disconnect.
Whether or not you have pure white or pure black is irrelevant.
Letās start with context of what the 65% max power represents. 65% power is 65% power irrespective of burning an image, fill, line, grayscale, etc. Itās literally 65% of max power for the laser module. What that max power translates to in terms of actual output power is unknown to LightBurn.
The entire grayscale range is fit within the upper and lower bounds of power settings. Check out this diagram for examples of how grayscale ranges would map to power % level.
Thank you so much for your assistance!
Just throwing this out there for future thought, it would be incredibly helpful if Lightburn had the option to assess the 0 to 100 scale within the context of your image rather than holding the image to a pure black to pure white scale.
For example, lets say I had an image with tones of gray to white, and I set Lightburn to 65% max power and 10% minimum. Pure white would be assigned 10%, but it would take the darkest tone of gray present in the image and assign that 65%, then scale the rest based on the power/grayscale gradient.
I know that lightburn does NOT do that, but it would be very cool if it would. It would give us the ability to have a much greater range of depth within our image at the click of a button, rather than doing external processing in GIMP or Photoshop and hoping to schmooze it into a good range.
Iām glad someone got some benefit from that post. It took a good bit of validation and time in preparing.
Would this be fundamentally different than using gamma in āAdjust Imageā? Or some of other image adjustment settings?
It would automate the process and ensure it was perfectly accurate.
Additionally, adjusting gamma and other settings are more art than science and can be exceptionally helpful for achieving different results than what the image already has contained within itself, but doesnāt hit the mark a lot of the time for me.
For example, Iāve been playing with this purchased stock image for engraving lately (only a small sample of it so I donāt break any rules):
After dozens of iterations of adjusting it, I got it to something that would almost burn properly:
However, the pure black shadows on the skulls are far too dark to look nice right next to the brighter skull bits. So, I adjusted the input black levels on GIMP to reduce its blackest blacks and this will burn much nicer.
However, now, the imageās self-contained gradient is from white to middling-blackish-gray, so it doesnt take advantage of the full range of black to white for power, and there isnāt a good way that I know of to have it do so aside from setting the power to a higher level than I actually want in Lightburn so it has more difference between the shades (and since theres no true black or anything close to it, it wont fire at the full power I specified).
Iād love to know if Iām misguided. Thanks all your input!
Basically it sounds like youāre asking to take the existing full floor and ceiling grayscale values of the image and scale that across the entire power available min ā max power range. Iām curious how well this would work. Exposure, I believe, generally scales logarithmically if Iām remembering correctly, not linearly.
If youāre able you should try to POC the process outside of LightBurn and see how LightBurn behaves. I feel like youād end up getting banding since youād be taking a small set of grays and trying to expand that to a wider range. 8-bit grayscale will only have 256 discrete values. Not sure if LightBurn can handle 16-bit grayscale.
@mchaney2003 This is EXACTLY what I was trying to get across.
Thank god itās not just me!
Just to be clear, what @mchaney2003 is describing is how heād like this to work. Or at least an option for it. Not how itās actually working.
@mchaney2003, Iāve modified your example to simulate the effect of treating the low and high values as end-caps of a full grayscale range. Hopefully Iāve done this correctly. But this should simulate the effect youāre after. Try burning this at whatever min/max power is appropriate for you and see if it yields the output you expect.
well mark me down as one for the āwishesā team then .
