Hello Squid
I installed on a skr smoothieware lost from the cohesion3d site with active clustering, unfortunately I noticed that images with active clustering are less resolute than with clustering disabled.
Does the same thing happen to you too?
hi all,
my english is a bit weak, as i am not a native speeker. i hope you can follow my anyway
i tried to follow the guide and make my btt skr v1.4 (chip: LPC1768; non turbo) run smoothieware on my k40 laser. but i get stuck. i installed marlin 2.x without any issues, just to ensure the board is okay. than i went back to smoothieware by taking the following steps on my win10 x64 pc:
download of firmware-latest.bin from https://github.com/Smoothieware/Smoothieware/tree/edge/FirmwareBin
renamed it firmware.bin
downloaded yassins config from https://justpaste.it/5turh
copied the config into config.txt (ASCII encoded)
copied firmware.bin and config.txt to micro sd card
connected the skr 1.4 to usb, inserted the micro sd card and pressed reset button
about 10 seconds later the sd card was auto mounted on my win10 pc
content of sd card: config.txt and FIRMWARE.CUR
no stepper drivers mounted yet; board only powered by usb; not endstops; no lcd etc. connected
started demo version of lightburn, started âfind my laserâ anf found âSmoothieware (200mm x 200mm) at COM4â and âSmoothieware (200mm x 200mm) at COM5â
selected the one connected to COM4 and clicked on âadd deviceâ
output of console windows:
Waiting for connectionâŚ
Smoothie
ok
ok
Homing
ok -
entered command M119 to check endstops
M119
ok
oknote: no endstops installed = open = 0. looks fine to me
started proterface to check the endstops
ConnectingâŚ
Printer is now online.
M119
SENDING:M119
my questions are:
step 4: the config from yassins contains some strange characters after the #. as i understand this comments are ignored from smoothieware. this will not cause any issues, right?
step 9: do i need to connect any thing to the board for a testrun via usb and pronterface?
step 14: any idea, why i donât get any response from my board when using pronterface? i am using a short quality usb cable with ferrits on both ends.
i plan to run tmc2208 v1.1 drivers on my board. how do i config the drivers?
does some of you got the skr v1.4 running smoothieware on a k40 laser and is willing to share his firmware and config file?
with kind regards
michael
Use smoothieware cluster mode firmware: https://www.dropbox.com/sh/bdssk5ya9ipb5ru/AADe3IKHcc5cI4DgK28jDFWCa?dl=0
Hi Bonjour,
i have tried the cluster mode firmware, but pronterface ist still not working. i am still trying to find out whats going wrong
okay, i managed to get pronterface reporting the endstops by sending M119. i had to compile the firmware by myself. the response to M119 is now âX_min:0 Y_max:1 Z_min:1 pins- (X)P1.24:0 (X)P1.25:1 (Y)P1.26:1 (Y)P1.27:1 (Z)P1.28:1 (Z)P1.29:1â.
my tmc2208 v1.1 drivers are running fine. i jumpered the board according to the btt skr v1.4 manual.
next i will deal with the pwm output.
michael
But none of you have problems in clustering mode? Iâm sure I loaded the right firmware (the one with clustering), but the clustered image once burned by the laser is different from the one without clustering, (top not clustering)
(worst resolution)
@Squid look at the Atomic Pi for a cheap x86 board to run at your laser. It some installed with 18.04 Lubuntu and Iâve run LightBurn on it without issue. Pretty amazing little board. I think on Amazon they now come with a wide angle camera module too.
Thanks Doug, Looking good. If I wonât find a cheap second hand laptop i will order an Atomic Pi. Price wise - Atomic pi + KVM might wonât be as cheap as a used old laptop.
We shall see.
Cheers.
Agree, if you have to go out and purchase Keyboard, Video display, Mouse(KVM) units too an old laptop with 2-4MB of RAM could be cheaper. Another option, if you can figure out the setup is to use VLC for remote desktop control but it wonât help you at the laser itself.
