skip1
(skipburton)
1
In settings I changed in better for diode from inches /mm/min to inches / mm
JohnJohn
(John Johnson)
2
is this about the burn time being slow:
Burn time running slow
or the wavy lines?
or the z-axis lifting device.
i’ll merge your result into the correct thread and mark it as solved.
Glad you found an answer.
system
(system)
Closed
3
