Hi this problem seemed to come, then go away and now it is back so I need to request help again if anyone has any idea. The original post is here.
Basically, laser intensity is different depending on where you are in the Y axis. I’ll attach 2 picture examples. Thinking my next step would be to change the belt, I changed it a couple months back though, doesn’t seem like it would be the issue.
I’d like to apologize for wasting your time. I think I know why this happened. I didn’t realize it but I was in rotary mode for quite some time. Realized today. The apology is because I believe you helped me with another issue that was likely caused by the same thing, back in February. Today when I turned off rotary mode, it started acting similar to the problem in February. I could tell I needed to calibrate the axis again. Got me thinking. Stupid rookie mistake. Can’t believe it went on for this long to be honest. Regardless, thank you for your willingness to help.
