Laser not moving properly
So my DIY algolaser 10W only moves a little bit each time. When I do homing it says: ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
I don’t understand this, but even if I just move it using those arrows in lightburn or laserGRBL, it only moves a little bit. Does anyone know what I can do about this?
Can you elaborate on what a DIY algolaser is?
Are you currently in the initial setup of the machine or did this at one point work? If this is initial configuration I’d suggest reviewing the steps/mm settings ($100-$102).
If this is the same problem you’re describing in your other thread, please keep the discussion over there so everybody can follow along.
Thanks …
Per his other thread.
@JohnJohn , I just responded to this in another, duplicate thread. Same symptom description…
Thanks for the heads up. I locked this thread and emphasized the link to the other thread.
