Hello,
I am a new user of the LightBurn software, and registered on this forum “emergencyly” because I did not understand the origin of my problem, and did not find a solution.
First of all, congratulations for the quality of the software and too bad you are abandoning Linux (the .AppImage solution seems to be a good choice…). I am a bit lost in the menus, but that is because I am a beginner and am French-speaking while the Linux version of today is only in English…
I am an MDF “cutter” more than an “engraver” and have had this Ortur OLM3 machine for about 6 months. Everything was fine in the OLM3 relationship and the hardware worked on while I was using the “LaserGRBL” software (LGrbl). I laboriously built myself a table of [passes-speed-power], for about ten products and everything was fine on the execution side. The “CAM” component of the CAD software I use is deplorable and I have to optimize objects and movements myself, which is not very complicated when there are few objects, but above all very tiring, without forgetting that there are many small actions to be carried out, forgetting one of which can ruin everything else. I found that LightBurn did this optimization work that costs so many hours and attention. I have been using Linux 100% for twenty years and, oh miracle, there is a Linux version of LightBurn!
Taking advantage of this possibility of “layers”, and currently needing to engrave and cut 5.5mm thick MDF, I embarked on a first creation in LightBurn. An engraving then a cutting of the same 5.5mm MDF board. My dream crumbled during engraving, when the LGrbl settings were [P-V-P] = [1, 200mm/min, 7%], and for this setting, LightBurn only gave me a bit of a line of 1 or 2 mm and then nothing! I got a satisfactory engraving with [1, 200, 20]! As for cutting, I saw that the setting at [4, 200, 60] had not cut: four additional passes… and still nothing. I tried [4, 200, 100]: still nothing! a second time… but while trying to check, I clumsily moved the laser head: the work was thus ruined! After breaking the MDF plate, I see that the cut is about 4mm deep, instead of 5.5mm. And here I am on the forum.
The “LightBurn performance declining” topic on the forum puzzled me. I read that Mike Finley had a similar problem, but that this change was not due to switching from another software to LightBurn, but to a change in LightBurn version. Haaaa. Oz Owner also says that you just need to check the “Constant Power Mode” box in the “Cut Setting Editor” window: I have my solution! Unfortunately, after searching AND abandoning beginner mode, I did not find this “Constant Power Mode” checkbox (I remind you that I am running Linux version 1.6.04).
For me, this point risks making LightBurn unusable (at least for cutting), and I only have 20 days of trial left!
What should I do to get LightBurn to switch to constant power mode for me to be able to adopt it?
