When I hit the home button, all that happens is the job indicator goes green and will not stop this until I hit reset. Also will not recognise the work area (520x490mm). When using User Origin or current position then it wants to move towards the lower left corner untill it hits the limit switch.
Are your laser correctly set? In controller and in Lightburn?
What was your steps for correct configuration?
Give us a little more.
Also check the following:
