How can one use lightburn with support for air and gas assist as well as the other functions eg. punch settings (punch time, punch delay, auto focus )?
Thank you
GV
Thank you
GV
Which controller and version of RDWorks are you using? I haven’t seen or explored these settings before. (Also, are you the same person as this post? The wording is identical : Support for Ruida Metalcut Functionality )
No i am not the same Person, but i have the same Controller Ruida 6332m. Using RD Metal Software for Metalcut.
Gv
Those are already supported in the cut settings:
Make sure you preview to check where they end up. It’s not as smart as I want to make it just yet.
Hello,
thanks, but it does only the Outside Lead in/out.
How to do Inside?
GV
Set the angle to a negative number. Positive angle on the left, negative angle on the right:
Hi
I originally requested the support for RD Metalcut.
Controller Version: RDC633XM controller and
Ruida LFS-AM-T43 Analog Metal Live Focus System (with a touch screen)
See https://www.aliexpress.com/item/32792794216.html
Ruida Software used: MetalCut V1.00.16
See https://www.cloudraylaser.com/pages/download-link
Regards
Alrich
