Where do I find every necessary setting for LM3 extension rails that needs to be changed? I changed the Lightburn to 850 x 400 … Thank you in advance!
I believe the LM3 extension increases length of the Y axis. Can you confirm? If so, make sure it’s the height field in Device Settings that you’ve made 850mm. The way you’ve listed it implies that the change was made on X axis.
Additionally, you’ll likely need to make a machine setting change.
In Edit->Machine Settings change $131 to 850.
I’m sorry, I thought I made it clear about the “y”, but maybe tht was the email to Ortur, I appreciate your response and question, I discovered that there were multiple locations that the 400 had to be switched to 850. Thanks again, hoping I’m good for a while!
