I was away on a personal matter. You’re doing just fine. At a glance it still appears to be a lost motion problem but I’ll review all the current information here before weighing in.
When LightBurn begins communicating with the C3D board, does it offer a Smoothieware Firmware version number?
I took your file and burned it with my laser machine. Everything looks in the file.
So it is not the file. It is either in the transfer from Lightburn, which JohnJohn is looking into, or, it is a mechanical issue. If you need anything from me, just ask. I think JohnJohn will figure it out for you.
Jack You are right, the guide line should be in the centre of the slot…
To me that’s not the problem, I can easily handle an edit to fix that. The big problem is the gross miss alignments, like this:-
Where the out side cut is is displaced upwards.
Other cuts have much bigger layers displacements, can send u a pic tomorrow, if u want.
Trevor
It’s getting closer and closer - It still looks like Lost Motion.
This can be caused by acceleration that is too rapid for the machinery.
The errors are getting smaller and smaller.
As a diagnostic criteria, are the inside shapes and the outside shape sized and shaped correctly? - This will confirm that motion is still being lost on traverse moves instead of engrave moves.
A second diagnostic question: Regarding the two short vertical lines to the Left of the Number 5; are they engraved consecutively and are they the correct distance apart? This may show us that the traverse is showing the symptom.
I found the config file on C3D’s site:
I’d like to compare these settings to the ones you’re using.
Please share the backup of your config.txt file in a thread here.
It should drag and drop into a reply with no issues.
It appears that final tuning is in order.
forces axis Y to top and produces Y motor/belt chatter
So i’m thinking the only problem i really have is the displacement of the cut layers.
What do u think ?
I think he’s asking for you to enter $$ in the ‘console’ and it should print the configuration settings to the console.
You can scroll the console and ‘copy’ the text, mark the text and use ^c (hold the control key and press ‘c’) to copy the marked area.
Use any text editor and open a new file called config.txt and ‘paste’ (^v) the information there. Save and close the editor and drop the config.txt file on the reply window.
The Frame position does not match the actual lines position, that’s why the above pic shows the lines off the work area, if i shift the start position to home ie Top LH goes straight into belt slippage…
Trevor
I can not measure the distances between the short lines. It is possible that the y-axis acceleration is set too high for the mass of the machine causing the lost motion. If the vertical lines are engraved consecutively and are generated at the wrong distance apart then we have a piece of evidence to point toward an acceleration based symptom.
On smoothie, it’s different - there’s a config.txt file on the SD card that ships with the device. FluidNC and some of the newer G-code (but non GRBL controllers) use a file and the ‘$$’ command doesn’t work. I poured over the smoothie docs and didn’t see a console command to pull all the settings. There is a ‘config dump to console’ command in Fluid NC.
@flynet
I Just noticed your optical laser for framing in the corner of the picture you posted.
On occasion, I have seen this type of accessory reduce the available Y-axis travel. If the work area is not reduced in the settings (to match) it will crash into the rail closest to you and furthest from the limit switch causing the controller to lose position.
With the K40 powered down and the computer disconnected (wait a few minutes) then slowly move the engrave head the full distance of the Y-axis to confirm the physical travel distance available. Please measure this - a tape measure should be adequate.
We can then confirm that the axis length matches the Machine Settings.
In LightBurn, click Edit then click Machine Settings - then click the small > to reach the Output Settings. Please screen capture everything in this window.
Adding mass (weight / heft) to the engrave head can require lower acceleration values to prevent belt slip - So, I’m still not certain what’s happening.
After we get this sorted, the Pointer Offset setting appears in the Device Settings window. We may have to adjust this if there are inaccuracies between framing and work location.
Looks like the cable tray was restricting travel, need to test other former’s, but looking good.
If this is the solution, have to work out how to get Air and Volts to the diodes.
Trevor
Another test on f8, still producing layer displacement,
Start from current pos. ie Home. no chatter…
John You say:-
Have 2 choices Settings and Device Settings, Which one?
Can’t see “then click the small > to reach the Output Settings” in either window… Trevor
If the option to access the Machine Settings isn’t shown, it’s entirely likely that it’s only available and accessible in the Config File on the SD card. Smoothie is a new process for me and I’ll be ordering a C3D board right away.
