Hi All.
Anyone know where to find the conifg guide? All links through google take me to malware sites since cohesion3d site is no longer up. Thanks in advance.
Hi All.
there’s a special version of smoothieware software which allows clustering gcode’s. You need it installed on the cohesion3d board OR a smoothiware compatible board (it’s what I use). After that it’s just a config files which needs to be changed for your laser. If you need more info, pm me and I can find all the relevant information for you including firmware and config files. I always knew cohesion3d was a bad idea so I’m glad I never re-installed there board
This will get you a firmware.bin and a config file
SmooChanges.zip.txt (42.0 KB)
and this is the source changes needed for clustering
Thank you sir. Will give it a try this weekend
You have it here on Ghithub:
https://github.com/search?q=Smoothieware&type=repositories&s=updated&o=desc
Also check this topic Latest Smoothie Clustering firmware for Smoothieboard v1.1? - Smoothie - Maker Forums
