[Edit: It was “Overcut” setting causing issues. Not sure why it started now.]
It did not resolve the setting globally. The lead out appears to be being done by new firmware, not sure.
I do not see the lead out lines in the lightburn preview…
These shapes are all on the same layer.
The bottom row is with Lead Out turned off
The top row is with Lead Out turned on, but at 0 length
Even the larger squares are burning a lead out, but the angle almost follows the existing cut line. I hope it follows it perfectly on my larger shapes… testing testing
[edit: it was actually overcut setting causing the issue]
